x_789
Gone - bye bye.
Well I bought a fantom a few months ago and since then I have had some issues ups and downs shall we say. Since I bought this Fantom Numerous times I have had people ask me what I thought about it. I told them that I would let them know once I came to a conclusion because I did not want to speak until I had put enough time into it well now its time to tell you what I think.
Ok I bought this fantom just over 3 months ago and when I got it I was pretty impressed nice looking motor seemed to be manufactured well but the carb had the idle screw too close to the inlet so it was near impossible to get a zip tie around the filter without it being a pain in the rear. This has been alleviated with the 03 models from Fantom because they have changed carbs and there is no longer the issue of the poorly placed screw. When I asked the support person at Fantom about this he said that originally they did this because they thought it would hold on the filter and people simply would stop using the zip ties WRONG. Bad Idea and they changed it for 03.
Initially when I got the engine I pulled out the instructions and read about how this new motor was ABSC (Aluminum piston, brass sleeve, silicon carbide coating) instead of the normal high end standard ABC (Aluminum Brass Chrome) These types of engines were sold by Fantom and HPI in there 2002 model engines. This process is supposed to be superior to Chrome sleeves. It is a process used in F-1 racecar engines is what the manual said. So the instructions say that this motor likes to be run at 270 and to not let it idle on break in. Instead you are supposed to drive it on the first tank to heat it up enough to break in this silicon carbide sleeve because it takes high heat to break it in properly. I went against my normal break in procedures and did it exactly like they said. Well this thing seemed to have some pretty good pep. After break-in was finished then I started tuning on it. I took it out for the first day of bashing and it was running ok then it would just die and was hard to start I was running about 250 to be on the safe side of what they said. First impression the temps jump drastically both ways and it wouldn't idle for anything. This went on for a few trips where it would run ok then once it warmed up it died as soon as you let it idle. I ordered a seal kit pulled it down and resealed the whole motor. Back to factory settings and lets try again. Got it tuned ok then I went out and to run it. Once again after it would get hot it would not idle for anything.
Now we have to take a step back at this point. I had contacted Fantom about a week and a half before I was starting to wonder why this thing would not idle. I attempted to contact Fantom’s Customer service because of the crank and it not being threaded down far enough. I ended up cutting out some of the end of my clutch nut so it could go far enough down to contact my flywheel. It was evident the problem was in the manufacturing of the crank. They did not thread the crank far enough down so the clutch nut bottomed out on the crank before it even touched the flywheel. Notice in the pictures below that the top engines crank has plenty of threads and notice the amount of space between the threads and where the crank gets thicker where the collet sits. The top is fine its a mach .15 cut to fit a Tmaxx and the second is a short version pro .15 crank I used to measure with, also notice the amount of space between threads and larger part of crank on the pro .15 engine. The bottom is the fantom it needs a minimum of 2 more threads cut into the crank and this problem would have been resolved.
Again I had contacted them over a week and a half earlier because people on this forum and others told me what great service they had. Well I didn't hear anything till almost two weeks later I can't remember the exact amount of time but it was more than a week and less than two weeks. When I was contacted I told them I had dealt with the crank issue. They told me they never had heard about this so I sent them links from 3 different forums where others had my same issues, along with pictures. They said they would contact their manufacture and look into it. At this time I have got half a gallon through this truck if not more and it simply will not run after it warms up. The idle has to be set two times higher than what it should be to keep it running. I also had a couple friends take shots at tuning it once it heats up it won’t stay running. Just wont Idle so I tell this to Fantom’s support they tell me to send in the carb, which I do. They sent me out a new one and I get the new style, which at first I thought did the trick. The night I installed the carb I tuned it but I didn't have but 45 minute to mess with it so I never really got to run it hard. Below is the old carb then the new carb pictures notice the asinine idle screw on old model.
old one
new one above
Well I got the truck out again. I was all ready to run the truck with the new carb installed and ready to roll. I got to do a little tuning and then I broke some stuff end of that trip. So I fixed what was broke and went out to run again the next weekend and the new metal throttle lever on the new carb broke in half as soon as I started it. Well I got a new lever put it on and tried again a couple more times. I never was able to get this motor to run out of 4 more trips out after it would warm up it just wouldn't Idle not to mention this thing had NO bottom end even running 16X72. I got smoked buy a 2.5 and a couple OS .15 CV motors notice I did not say CV-R motors.
Well yesterday I finally had it I pulled the piece of junk Fantom off and installed a .12 OS CV-RX engine I had sitting around I ran it 18X72 and it smoked the Fantom everyway from Sunday. Well after talking with a couple buds they tell me that Fantom changed back to ABC sleeves for 2003 and sure enough I looked in a Magazine today and their add says ABC sleeve. They also changed colors of the head big deal. Oh another bad thing was the head does not have a button it’s all one-piece. So screw up threads for glow plug, you get to buy a new head OUCH. Anyway after doing a little research it seems that from what I have heard and found on another forum the ABSC sleeves wear out QUICK. So it looks like my problem was a dud sleeve. Well I am not about to spend over half of what I paid for this engine to get a new ABC sleeve, because Fantom figured out on guys like me that the ABSC was a bad deal.
I just want to finish with these comments. I bought this motor because I heard lots of people talk about how good they are and I trust some of these people. Maybe it was just the crapy sleeve and if I got an abc sleeve it would solve all my issues. But honestly I am not going to waste my money to give them another chance. There will be plenty of folks in here talking about how good their Fantom is and how good Jeff at Fantom’s service is but I am simply telling you my experience from now on Its OS and TRX 2.5 for me ONLY.... X
