Nice sir! Don’t see those old girls that often anymore-let alone that clean.
Without checking piston to head clearance you will be fine at 25% and a hot/ultra hot plug. If you wanna run 30%, I’d for sure check your clearance-as you’ll likely require at least another .1mm shim in your stack. Always read your piston to verify your engine is happy-that’s the best advice I can give for sure. Math is math, but it ALWAYS boils down to what your engine likes, and if it’s happy with your combo. Track surface, vehicle weight, ambient temps/humidity, traction, gearing, etc., will all contribute to what it wants. Hope this helps. If you have any more questions, feel free to tag me-and I’ll do my best to sort you out.
