My HPI Baja 5BSS as it is now - shorty
olds97_lss
RCTalk VIP
Dekalb, IL
Considering it barely fit in my trunk with my carry bag, I thought I'd try to shorten it up a bit. With my limited ability to machine things, I bough the scorpion shorty kit.
After a bit of swearing and banging on things with a hammer, I got it sorted out. Fits better in my bag now and in my trunk. Also seems better proportioned to what it is. Flys just as good, handling is quicker, so all in all, a better rig for me... when I have time that is.
Now to find some taller tires for better ground clearance... and cvd boots that last more than a couple tanks of fuel before giving up.
I did the black mesh thing all over the chassis as the scorpion chassis has cut outs all over (sides/bottom) to lighten it. I asked them if they ever intended on doing a chassis without cutouts, answer was no. So, will either be making aluminum plates to cover things for snow running or see how the screen I put in keeps the snow out when the time comes.
Also thinking of getting a second set of tires/rims like I have on the rear for teh front to give it a more aggressive look and possibly better feel on the landings.
I upgraded the front tower as I busted one of the uprights my last time out. I also bought some tubing to cut the roll bar so I could take the front off without taking more bits off to get the stupid thing off. Seems to be holding up just fine.
Anyway, here are some shots of it:
Nice work Olds, looks good man. Try the Hostile gray boots (the gray is a different material and therefore you can run any grease you like in them). Also, if you're still running sway bars, you need to trim a couple MM's off the rear so it doesn't rub the boots when the suspension cycles. I think Rob came up with that one.
Looks great.
5T tires/wheels are taller than the 5B.
Yes they will.
Did it change its performance at all? Like maybe its easier to keep it leveled in the air now? I see so many vids of them just nose diving.
Seems to be a lot better in that regard where I run it. Most of the earth jumps I have aren't long, so I was getting a lot of nose diving if I didn't gas it just right. Turns a lot quicker now as well.
