That MMP combo is a 2400 KV motor; do the math.
If your stock motor was the 3,500 KV, on 2S (8.4v) it would free spin at 29,400 RPM
A 2,400 KV motor on 3S (12.6V) will run 30,240 RPM
Ergo, your top speed should be roughly the same if you did not change gearing. You can gear up a little, though my personal experience running SCTs on 3S with 1/10 electronics has been less than good, and gearing it taller will only further strain the system. IMO, due to the size and weight, SCTs should be given 1/8 scale bits when you want to push them harder. I'd bet on short ESC life if you start hitting that thing with 4S.
In my Prolite, I dropped the stock 3,500 KV 550 can and XP900SC ESC in favor of a Kyosho Vortex 2,000 KV 1/8 can and a Hobbywing SC8WP 1/8 ESC. I also went from a 14T pinion to a 20T pinion, thus my top speed is about 20% lower on the same 3S battery, but the motor doesn't strain near as hard. I could gear it up further (or run 4S), but the thing is plenty fast as is, still able to run 47 MPH.
