Ckeithnitro
found a online print of a timing disc, printed it the size of a dvd disc..
laminated it, cut it out of laminate, gorilla glued it to dvd disc use center crosshairs to get center of dvd centerhole..
cutoff clutch shoe pins off a flywheel..
gorilla glued it to the back of the disc. using crosshairs to get center of disc again.
easy mounting with use of flywheel and clutch nut..
here is the timing disc setup on a 5.9 Used piano wire for the reference pointer..
