- Southern Maine
- Racing
Good point!!!Oh! @JustnWynn , do not leave that servo plugged in while not in use. It will suck that battery dry, like an ex-wife.
You have to take those big tires into consideration with regards to your gearing. As cool as it looks, it is going to put a monsterous load on your motor, and ESC. You have to adjust your pinion/spur accordingly. You do that by calculating your final drive ratio now, compared to the typical ratio with stock gearing, tires, and motor. Use the pinion and spur to get back close to your original final drive ratio. Or if you upgrade the electronics to handle more load, you adjust for those electronics. With those tires, you are very likely going to burn things up very quickly if the motor/ESC can't handle it.
Looks great though! So get out your calculator and make them work![]()
they are 6.5 inches, sirWhat's the OD diameter of the tires?
My Gorgon tractor tires are 5-1/2" tall. I didn't change the stock spur or pinion but it's brushless 3500 & 100a so it gets on pretty good. The 3660 has some torque. I'd imagine there are smaller pinions for your build, but don't know how much smaller. IIRC 13t is stock, 11t may be the smallest but idk what motor shaft you have. It may amp out & get too hot.they are 6.5 inches, sir
ok.. on it. one momentWell, after looking at the transmission gears, I am actually calculating it at 3.55:1. So we gotta get this sorted. 3.55:1 sounds much more typical.
Mark a tooth that you can time with a mark next to the spur, and put a dot on your tire aligned with something on the chassis, or setup a stick taped to the chassis to line up with the mark. Rotate the spur til you get one full tire rotation. Make sure to count the full spur rotations. Once the tire rotates fully, count how many teeth the spur rotated past your timing mark on it's last rotation and let me know the full rotations, plus the extra teeth that went past it.
I am hoping you see 3.55:1.
My opinion, since you asked, is that all the work and nonsense and double back tracking and refiguring was ALL worth it!!!good morning everyone! wanted to say thank you again for everything... I'm at a good stopping point for now i think. gotta try to keep it fun. yesterday was... trying on my patience. lol
gonna move on to my other project. the toy grade to halfway hobby grade. the wifey and i are doing some painting today for that one.
but i wanted to show off my big tires in case anyone was curious as to why i got that big servo![]()
then this is the shell that i'm gonna try make work with it.
thats it for now.
opinions are always welcome!
cheers, fellas
