I have finally gotten some free time to work on this.
Here are some progress photos.
While waiting on my Losi V3 CVD's, I added some bling to my DX3R.
V3 Losi CVD's
Gears installed and lubed with Rocksmith Engineering Gear Jelly
Completed rear axle
Eritex MOA conversion motor mount
Holmes Hobbies 7T puller motor installed
MOA gears
MOA gear cover
Front axle completed with a Rocksmith Engineering steering setup
Had to move battery mount back 10mm so it would not interfere with the long ass puller motor can.
Steering servo
Here are some completed shots before I decided where to mount the electrics. The bag is over the motor because I have some drilling to do on the chassis for the mounting plates. I had not covered the other motor yet.
Punk RC Dig Switch all soldered up. Man I love my Hakko 936!
As of this evening I have essentially completed this build. I have mounted all the electrics and gave the rig a quick test in the workshop since it was raining when I got home.
I did have an issue with getting the Punk switch to work with my DX3R. It would only power the rear motor and would not cycle to the rest of the setting. I was in severe frustration mode and had to walk away for awhile. I send an email to Punk RC yesterday evening and got a response within an hour.
The problem was that the DX3R frame rate come preset from the factory at 5.5. In order for it to work with the Punk switch, it must be set to 11. Problem solved.
I will take some final pics of the build and post them up hopefully tomorrow.
