Looking for help with building a drift rc car
Addict Rc
Massachusetts
I was thinking of using a
Hobbypower 1/10 Alloy & Carbon RWD Drift Racing Car Frame Body Kit for Sakura D4 and then a ecoboost servo I need suggestions for a 13.5 turn motor and ecu and also a reciver​
can't go wrong with Tekin products especially with the touch button programming on all esc by tekin...bump the timing up on end bell and see how well it will run
I would get a flysky radio / reciver then you can add more kits as you get more.. you can't go wrong with a tekin set up. Can also look at the castle. For your esc motor combo..
The 2 motors that are used in RC drifting are the 10.5 and the 13.5. Depending on what surfaces you are running. Hobbywing has a good combo for arou d 130 which is what I use. You will also need a drift gyro and a drift steering servo to get the max out of it. I go to a shop locally that has a track and I drift a YD-2AC
