I posted UE and RCAlloys as conversion sources because I know they do it right. There are less scrupulous outfits out there that will use the Hyper crankshaft.
I have a UE modified C5 and it definitively has the original crank. The modification requires that a hole is drilled in the crank pin. The C5 and the Hyper do not have the same stroke. So the hole needs to be slightly off center. Then you use the one-way bearing, backplate, and pullstart assembly off of a hyper 8-port to finish it off.
If someone offers to do the conversion and asks for a Hyper crankshaft, then I would stay away. The Hyper crank is not only of lesser quality, but also the stroke may not be the same.
Tex
