Laptop help
Mayhem
I have this laptop and when it starts up it tries to load novell the file is missing is there a way I could bypass loading this file? its a NEC Vera LX with Window's M E
I'm a little confused as to what you are seeing. Does this machine dual boot with winme and novell or is this a novell networking file windows is having trouble loading?
tell me what you see in order. maybe I can help
I think its a novell networking file.
I see a number of errors that look like this:
Module C:\NOVELL\CLIENT32\NBIC32.NLM did NOT remain resident Press any key to continue then a get about 10 more with different file names.
also NIOS-202-105: An attempt tp load LSLC32.NLM falild b/c the specified file could not be found.
do you use novell networking? are you in a novell network or did this laptop just come this way?
It's not mine I don't think he uses it. So if we could get rid of it that would be fine.
Well you have two options. If the laptop still needs to connect to a Novell network you will need to download the client and reinstall it on the laptop. This will clear up the error.
If the laptop does not need to access a Novell network just remove the Netware client in the Network Properties and just use the Microsoft Family Logon as the client.
its not in the Network Properties
Try claening the hard drive and uninstalling that program. You should be able to do that?????
Really? Hmm..what is listed in there? Well what I would suggest is downloading the newest client and install that. Then once it is installed correctly and the system boots up correctly go to the directoy and find the exe file called rollback. This file will uninstall the client. Removing Netware can in a PITA sometimes. It does not adds its self into the Add/Remove Programs.
Go in the the regerestry thanks NoviceROB!!!!
