HYPER 7 PCR using PBS or C HUBS?
jon2
Nitro ASSpired!!!
Oxnard
Ok I am really frustrated. I just got the Hyper 7 PCR and it came with two type of suspension set ups. PBS and C hub. What is the actual H7 PCR Pro supposed to have? Also Since it is the Hyper 7, the chassis says Hyper 7L. Does that mean it is longer? The reason I ask is because my front aluminum brace is few mm's short of the hole on the chassis. The rear is fine but that is just a biotch.
Thanks fellas
Jon
the hyper7 PCR should come with PBS suspension. but if you got both. set it up how ya like. i personally run pbs front and c-hub rear in my 9.5.
no clue about the chassis. sorry
wiita
Thanks Wiita. I have the PBS in the rear but I will change out to PBS in the front. I read that is stronger than the C hub.
Ok I checked on the site and it shows the PCR Pro with Front C hubs. Funny thing is that they say the Pillow ball set up is better for Bashing and jumping. What is the real truth? Opinions?
only thing i could think would be that c-hub suspension sets your camber in fixed increments. without a camber gauge with PBS your kinda guessing about camber degrees. i'm not a serious racer, but i take my races seriously! i swapped to the pbs on my front to have the ability to make small increment camber changes for my local track(s). i've also heard the pbs is tougher, due to thicker nylon, but both will take a serious beating.
wiita
