HPI Nitro MT1 engine swap
pitbull14218
Buffalo
Hi everyone, so my hpi Nitro mt1s nitrostar .15fe engine is tired, the time has come to replace it.
I bought a used Team Orion crf 3-port .21 engine I’m hoping is in good running order, in order to install it.
A couple challenges along the way are going from a rotary carb to a slide carb.
Also engine mount.
Anyone ever do this? Any recommendations on engine mounts? The g3.0 engine mount is discontinued, can’t find it. Not sure if there’s anything else I can use to mount the engine.
Any recommendations with the linkage?
Not sure how your going to shoehorn a big block into that thing. From what I recall, it was pretty tight behind the engine and a big block is 3/4 inch longer and the header comes out of the back which adds more room to be needed. Also, the spur is very brittle. I went through so many of those stupid things in my NMT many years ago. I eventually gave up and just sold it.
As for linkage, I found this the other day when replying to a guy in another thread wanting to put a trx 3.3 in his older HPI:
Appears that amain still has the Nitro Star G3.0 (.18), fairly cheap too:
https://www.amainhobbies.com/hpi-nitro-star-g3.0-engine-w-pull-start-hpi15105/p55855
These should fit the hpi 3.0 engine, but you may need to make new holes in the chassis:
https://www.rcplanet.com/engines/en...l-block-engine-mount-purple-aluminum-red02128
So I got the engine I bought from ebay. My glow plugs won’t screw into the head, not sure if it’s stripped out some how or if the Team Orion CRF .21 3-port needs a special glow plug?
I’d also like to convert this engine to pull start since it’s currently setup for a starter box.
Looks like it might use turbo plugs, which are tapered at the tip vs standard plugs. NOt sure you can convert that to a pull start... also, looks like there are 3 versions of the 3 port, each have a differing crankshaft, so kind of hard to tell if any are capable of using a pull start. Can't really even find a pull start for that engine at all.
Oh, I didn’t realize turbo plugs are different.
Do turbo plugs only fit certain engines?
If I have to do bump stop, I suppose I will.
Yes. Turbo plugs fit turbo head/head button engines. Standard plugs do not.
Turbo on the far right, the left 2 columns are a mix of standard long and standard plugs. Standard plugs use a copper washer to seal. Turbo plugs use the tapered tip of the plug to seal.
And I think turbo plugs are larger diameter thread.
If I can't find a pull start, do I need a different flywheel in order to use a starter box, or can I use my original one?
tudordewolf
9
Desert Basher
Desert Basher
GhettoPistachio
4
1K
GhettoPistachio
GhettoPistachio
J’sCrawler
44
2K
J’sCrawler
J’sCrawler
