Question: What is a good break-in procedure for my new engine?
Answer: OK, here goes. The first procedure is called "heat cycling", this is the most important part of break-in and almost no one does it. Start the engine and let it idle, after 1-2 minutes feel the cylinder head, you want it to be hot enough so you can't grab on to it for more than 10 seconds at the base of the head. Stop the engine, make sure the piston is at the bottom of the stroke, let it completely cool down, back to stone cold. Repeat this process at least 10 times !!! I usually dedicate the first tank of fuel to this process. It's going to take some time to do this so be patient.
Now you can take it out and run it. Open the main needle one full turn. The next 4 tanks, run at no more than 1/2 throttle and vary the speed up and down. Let it completely cool down between runs and always make sure the piston is at the bottom of the stroke while it is cooling. Try to run the engine in the 200 degree range during this period.
Now 4 more tanks running up to 3/4 throttle, run it in the same manner as before.
Now you can go wide open, make sure to run it on the rich side for another 6 tanks. Don't try to grab a lot of ponies yet. ( this is easier said than done !!)
Now you can let it rip. These engines run best at temps 220 to 240 degrees. There should always be a VISABLE line of smoke coming from the exhaust stinger.
Good luck with your break-in. Take your time and do it right and you will be rewarded with an engine that runs stronger and lasts longer than you have ever seen.
NOTE: For all high performance engines - the Rody Roem Heat Cycle break in process is the best method. Here is how it is done -
Per Rody himself - Also there are some things I personally do not do is for example start the engine with an electric starter and this you have to do with a Hudy bench if you do not take off the protection. I of course cannot tell you to take of the protection for safety reasons.
Anyway, if you still want to do it in this way, I think in this way you cannot do a lot of things wrong.
So before you start to run in an engine I suggest you cover the cooling-head with something so the engine heats-up properly(without the cover the engine will stay too cold).
Then start the engine and let it run rich at full throttle for 2-tanks at a temperature of about 80°C.
Then 2 more tanks at 90°C.
Then 1 more tank at 100°C.
After this your engine is almost run-in, however you need to finish the rest of the running-in in the car for about 2 more tanks and you are then ready to go.
Hope this helps you further.
Sorry for the poor English, but Rody is french, and these are his exact words
