Hota D6 & D6 Pro Battery Chargers
RustyUs
Military Veteran
Pennsylvania, USA
This thread is for the general discussion of the Hota battery chargers. Please add to the discussion here.
Hota's chargers... https://www.hota-exp.com/index.php/pro_l_1.html
From another thread...
... So I have used it a few times now and it will only charge all of my batteries to about 75% per my battery checker. My other charger will charge to 95% or slightly higher. Is there a setting I’m missing on the D6?
Thanks
What is the voltage reading at the 75% mark on your battery checker?
Are you using the "Charge" function on the charger?
I don't remember the default end voltage per cell value used in the "Balance" function. A part of me thinks you have something adjusted wrong on the charger.
The voltage is in the right range for the batteries. Yeah I’m using the charge function and just the default settings the charger recommends. The only thing I change is the battery type and the function charge, balance and so on.
