I need some help figuring this out. I put weight on my scx10ii and went to a smaller pinion gear and twice in two days I've smoked my motors. I dropped to a 14 tooth pinion from 17 and the performance was good it smoked the motor after just about 20 minutes of crawling. Before the weight and pinion change it would crawl for hours on 3s and not break a sweat. I added a 333 gram brass set I got from Amazon and when I did the weight out of the box it showed 364 grams. I installed the whole set and when it doesn't smoke the motor it crawls amazingly. Any suggestions. I was running a 19 turn injora crawler motor and then a 16 turn reedy crawler motor. Any help would be appreciated
