Scx10iii coyote.
Martin trj
SoCal
  2. Crawling
I’m picking this one up tomorrow, I’m trading it for a mini b that I just don’t use.
Any upgrades you guys can recommend? It has axle portal covers and it comes with a fusion se brushless motor and I’m getting 2 batteries with it. For sure I’m getting new wheels and I’ll try to use the stock tires.
Thanks much 👍. I’m taking it to the rocks right after I pick it up.
I would suggest running it with the stock tires before you make any changes there. I have been amazed how well they work. I put them on the Capra and was blown away how good. Glued tires on plastic rims......sheeeesh!
Thanks guys. I intend to run it at night, any good lights you care to recommend?
the best RTR I have USED. I will say that I have not used everything out there....yet.
what type are you interested in? scale type lights or a bar?
https://www.ebay.com/itm/234157259546?var=533775362649
i have this light bar on 2 trucks, insanely bright, lights up the field like a spotlight, but do NOT look directly or even indirectly at the front of the bar or you're blind!
i actually got a few comments about the brightness at the rocktober event, i had to purposely steer my truck so it wasn't shining directly at anyone
It gets really dark there so it might be a good idea.
They’re Dashrc, never heard of them but they are very solid. Now the problem is that on the very last tire, I became impatient and I pulled it wrong…I put a few drops of super glue, we’ll see if it holds up. If it doesn’t, what replacement tires would you recommend?
I installed these lights.
i like the jconcepts megalithics and ruptures on a few of my trucks, i also rock a lot of amazon special hyrax clones, they are pretty good generally, theyir both pretty sticky so they grip when you're trailing over rocks, and they handle dirt and leaves pretty well as well. @MVRCA does a LOT of tire testing from a profesional standpoint, i just throw tires on trucks lol he would have am uch more informed opinion than myslef
