bizzare6996
Electronic stuff:
7 cell 110 mah battery (2 of these) corvair $25.00
ace r/c auto add a trickle $18.00
ace r/c edc-01 charger/discharge/cycle $30.00
ace r/c super series super smart charger $60.00
airtronics 30" extension cable $5.00
deans 6/7 cell battery kit $5.00
deans 6/7 cell battery kit (2 of these) $5.00 each
eflite apex charger dc $25.00
fatuba 72.450 ch.33 crystal (2 of these) $12.00
fatuba fm 72.030 ch 12 $12.00
fatuba fm 72.070 ch 14 $12.00
fatuba fm 72.090 ch 15 $12.00
fatuba fm 72.130 ch17 $12.00
fatuba fm 72.630 ch42 $12.00
fatuba fm 72.650 ch.43 crystal $12.00
fatuba fm 72.690 ch45 $12.00
fatuba fm 72.770 ch49 $12.00
fatuba fm 72.890 ch 55 $12.00
fatuba fm 72.950 ch58 $12.00
great planes electrifly 5 channel fm 72mhz mini reciver with built in 30 amp speed control $50.00
griffin 55 by castle creations motor controller 55 amp micro speed control $60.00
gws flight pack for indoor and slow flyers for jr systems $60
hitec coreless high speed all metal gear ball bearing hs-925mg $50.00
hitec hs-125mg $35.00
hitec hs-225mg $25.00
hitec hs-5125mg $50.00
hitec hs-525bb $25.00
hitec hs-925mg high speed servo $50
hitec precision high speed servo hs-525bb $26.00
hitec precision highspeed hs-525mg $30.00
hitec programable digital min servo hs-5245mg $40.00
hitec sail winch hs-725bb $60.00
hitec standard digital servo hs-5475hb $30.00
jomar products ultimate battery backer jr/hitec $30.00
jr 2 ch am rx 27/75 mhz $35.00
jr 2 channel am 75mhz reciver $25.00
jr gear set alloy:ds3421 $10.00
jr gear set alloy:ds3421 $18.00
jr microswitch harness (2 of these) $8.00
jr r-102 2 channel am 75mhz reciver $30.00
jr standard rx pack 270 mah 4.8v square $12.00
jr standard rx pack 270mah 4.8v flat $12.00
mcdaniels r/c go-slow servo $20.00
mcdaniels r/c servo reverser kit $15.00
mcdaniels r/c single plug on board glow battery system $60.00
pickup sensor (3 of these) $20.00 each
park pal plus charger $45.00
sanyo 3000mah cadnica fast charge cells (6 of these) $5.00 each
sanyo 6volt 2400 mah battery pack $35.00
team associate motor connector amps (3 of these) $1.00
team trinity 11x2 amerature p-94 $30.00
team trinity 12 turn double amature motor matt francise world wind $30.00
team trinity motor break in drops (2 of these) $2.00
team trinity street spec brushes $1.00
trinity monster maxx pro 17t single hand wound motor $40.00
wattage 6 cell 800 mah 5/4aaa $25.00
wattage 8c 9.6v 500ar 2/3 a sanyo battery pack $25.00
xing mini charger delta peak autop cut-off quick charger $25.00
xtm racing r-box (eleminates the need of a 3 channel radio) $20.00
zagi 20 amp esc (2 of these) $35.00
zagi fix battery 370 mah 8 cell $20.00
hitec 72.130 mhz dual conversion channel 17 crystal $8.00
hitec 72mh2 dual conversion channel 29 crystal $8.00
hitec 72mhz dual conversion channel 53 (2 of these) $8.00 each
hitec 72mhz dual conversion channel 34 (2 of these) $8.00 each
hitec 72mhz dual conversion channel 59 (2 of these) $8.00 each
hitec 72 mhz dual conversion channel 33 $8.00
hitec 72mhz dual conversion channel 45 $8.00
all the hitec crystals are fm.......
TMaxx stuff:
hardcore racing steering linkage titan (blue) t-maxx $20.00
hardcore racing throttle servo mounts ba blue t-maxx $20.00
maxx factory bumper lights e/t maxx $30.00
maxx factory madd maxx wheel adaptors $40.00
rpm t-maxx/emaxx bulk braces front and rear w/mounting hardware (2 of these) t/e maxx $6.00
traxxas trunbuckles 105mm (rear toe control links)
traxxas transmission output yokes $3.00
traxxas throttle /shift linkage tmaxx $5.00
traxxas t-6 blue aluminum chassis t-maxx $50.00
traxxas suspension arms front $5.00
traxxas suspension arms front $4.00
traxxas starter shaft $5.00
traxxas output shaft/spacer tmaxx $4.00
traxxas one way starter bearing $10.00
traxxas machined connecting rod image .12 $10.00
traxxas graphite shock tower nitro/elec rustler $8.00
traxxas gear hub/one way bearing $20.00
traxxas exaust header blue nitro rusler $15.00
traxxas clutchbell steel replacement 16tooth $8.00
traxxas ball bearings 5x10 $4.00
traxxas assembled pullstarter trx.15 $12.00
Misc other crap:
xxx-t graphite chassis with graphite brace $40.00 obo
lunsford rc10 tc3 titanium hinge pin kit $15.00
yokomo rear body mount staybalizer gt-4 $2.00
trc onroad rear tires 1/10 mounted & tru-blue $25.00 set
thunder tiger differnetial gear bag $20.00
thunder tiger differential gear bag $25.00
ths racing high performance exaust 1/10 on rd $60.00
ths racing 1/8th on road tuned racing pipe $70.00
ths racing 1/10 scale on road tuned pipe with header $50.00
team trinity offroad shock dyno $8.00
team orion fresh kicks street tires ultra grip mounted 24mm ( set of four) $30.00 set
team losirear pivot plate xxx $2.00
team losi rr pivot block xxxnt $2.00
team losi rear axle spacer and pin $3.00
team losi one-peice diff nut/carrier $2.00
team losi monster diff drive rings $1.00
team losi monster diff adj screw set sport rtr $2.00
team losi inner rear hinge pins xxx $2.00
team losi hard adionized race wrenches .050" $8.00
team losi graphite rear arms str weapon $8.00
team losi full thrust bearing set xxx $3.00
team losi front spindles/carriers and hubs xxxt/xxxnt $4.00
team losi front spindles carriers hubs xxx $5.00
team losi front shock tower xxxt/xxxnt $4.00
team losi front shock tower nxt $5.00
team losi front and rear pivot block set xxx $3.00
team losi dog bone/drive shaft with yoke xxt $6.00
team losi a-arms graphite xxt $8.00
team losi 51t 32p spur gear xxx-nt $2.00
team losi 1.5 mm wrench $8.00
team associated flywheel collet rc10gt $2.00
team associate 75t 48p spur gear with diff ball holes $2.00
team associate upper suspension arm mount 12L-10LS $2.00
team associate upper arm hinge pins $1.00
team associate turnbuckle wrench for dynamic strut front end $2.00
team associate suspension arm pivot balls $3.00
team associate steering servo mount (2 of these) t2 $1.00
team associate steering rack set tc3 $2.00
team associate steel t-bar pivot ball 12l $1.00
team associate starting set/pullstarter comp blu 15 $20.00
team associate starting set complete blu.15 $20.00
team associate spring .024 $1.00
team associate spring .022 $1.00
team associate spring .020 $1.00
team associate spring .018 $1.00
team associate screws 4-40 x 5/16 sh $1.00
team associate rear shock tower b4 $4.00
team associate rear shock strut t2 $10.00
team associate rear a-arms tc3 $5.00
team associate nose brace tubes black $3.00
team associate motor clamp spring and screw tc3 $1.00
team associate lower suspension arms $1.00
team associate kingpin shims $1.00
team associate front/rear transmission case (2 of these) ntc3 $3.00
team associate front suspension arms ver2 tc3 $5.00
team associate front shock tower b4 $2.00
team associate front end fiberglass brace rc10l/ls $1.00
team associate foam bumper ntc3 $3.00
team associate fiberglass upper brace $4.00
team associate exaust manifold gasket (2 of these)
team associate engine adaptor for non pullstart rc10gt $8.00
team associate dual sport front nose plate aluminum black adionized $4.00
team associate drive gaer and shaft $6.00
team associate dogbone rear half shaft $3.00
team associate diff tube $4.00
team associate diff teflon bushings $1.00
team associate diff shaft with lf diff pinion $6.00
team associate diff balls $1.00
team associate cut off nut (3 of these) rc10gt $1.00
team associate brake shoes rc10gt $1.00
team associate axle bushings 1/4 x 3/8 x .400 & washer $1.00
team associate axle bearing hight adapter #2 $1.00
team associate 85t 48p spur gear with diff ball holes $2.00
team associate 83t 48p spur gear with diff ball holes $2.00
team associate 78t 48p spur gear with diff ball holes $2.00
team associate 72 tooth spur gear 48 pitch $2.00
team associate 69 tooth 48p spur gear $2.00
team associate 54 tooth spur gear ntc3 $2.00
team associate 54 tooth spur gear 1st ntc3 $2.00
team associate 50tooth spur gear 2nd st ntc3 $2.00
team associate 50t spur gear 2nd st ntc3 $2.00
team associate 50 tooth spur gear ntc3 $2.00
team associate .022 springs for 1/10 dynamic front end $1.00
team associate .020 springs for 1/10 dynamic front end kit $1.00
team associate .018 spring $1.00
team asscoiate bearings 3/16 x 5/16 (flanged) (2 of these) $10.00
tamiya front dogbones tao2 $5.00
serpent ventilated disk brake $12.00
serpent solid rear axle 46t impulse $20.00
serpent solid rear axle +46t (2 of these) impulse $20.00
serpent gear diff adaptor (2 of these) impulse pro 2 $18.00
serpent accu pack (2 of these_ impulse pro $40.00
rs4-mt $25.00
rs4mt $12.00
robinson racing diff gear hardened aluminum xxxnt $12.00
revolution multipoint 28mm sx wheel $5.00
raceway products hub tool double ended $10.00
quick fit coversion kit $30.00
proline mip cvd replacement bone fits proline suspension kit $10.00
precision machined yank eleiminator $20.00
powerline racing rear belt mount with tensioner (2 of these)
os cylinder and piston assembly 12z/12cv $30.00
os connecting rod 61sf/61rf $12.00
ofna spur gear hyper 7 $20.00
ofna shafts dogbones center 93/86.5 $15.00
ofna shafts dogbones center $15.00
ofna shaft 4mm suspension shaft hyper 7 $6.00
ofna rebuild kit shock set $8.00
ofna manifold,round port on road $15.00
ofna linkage sliders yellow $2.00
ofna front upper arms mbx4 $8.00
ofna front shock tower purple hyper 7 $5.00
ofna front a-arms upper/lower $8.00
ofna front a-arms upper lower $8.00
ofna drive joints 9.5 $8.00
ofna drive joints $8.00
ofna connecting rod force.21 $10.00
ofna 3 pin flywheel .21 corn type ultra gtp $8.00
nrs4 $18.00 each
novarossi onroad tuned pipe $60.00
nitrors4mt $15.00
mip shiny cvd kit/ls/nitro hawk/srt traxxas $30.00
mip shiny cvd kit rs4 pro/nitro/rear (wide) $28.00
mip shiny cvd kit (2 of these) rs4/pro/nitro front (wide) $28.00
mip 360 stinger kit rc-10gt $45.00
megatech front aluminum gearbox purple nitro mt $60.00
megatech aluminum skid plate and front bumper set purple nitro mt $20.00
megatech aluminum rear upper arm set purple nitro
megatech aluminum rear shock mount (purple) (2 of these)
megatech aluminum rear gear box purple rs4 nitro mt $60.00
megatech aluminum front upper arm set terra crusher $25.00
megatech aluminum front lower arm mounts purple nitro mt $18.00
mcdaniel r/csingle cylinder on board glow ignition system $60.00
lunsford titanium hinge pin set rc10b3/t3 rc10b3/t3 $15.00
lunsford super duty 3.5mm titanium turnbuckle&hinge pin set xxxnt $35.00
lunsford super duty 3.5mm titanium turnbuckle and hinge pin set xxxt $35.00
lunsford purple punisher pro wrench (2 of these) $3.00
lunsford punisher series traxxas nitro rustler titanium turnbuckles nitro rustler 20.00
lunsford punisher series titanium turnbuckles b3 $20.00
lunsford punisher series rc10 tc3 titanium turnbuckles and hinge pin set tc3
lunsford punisher series 1 1/4" titanium turnbuckles (2 of these) $6.00
lunsford punisher pro wrench (2 of these) $3.00
lundsford titanium hinge pin set rc10t2/gt $15.00
lundsford punisher series titanium turnbuckles hpi nitro rs4 $25.00
kyoshosp out drive assymbly $25.00
kyosho linkage rod set $5.00
hpi universal dogbones rear (3 of these) rs4mt $25.00
hpi universal dogbone center front nitro rs4mt $15.00
hpi universal dogbone (center front) nitro rs4mt $15.00
hpi suspension arm set savage .21 $8.00
hpi supershock set (62-87) front (2 of these) rs4mt $20.00
hpi standard rear hub left/right sprint $2.00
hpi stainless steel hinge pin set with rear arm (2 of these) nitro
hpi sprint suspension arms (1 front 1 rear) sprint $2.00
hpi spring 57x9x1.1mm black $2.00
hpi sport shock set 46-56 set $15.00
hpi sport shock 45-56 set $12.00
hpi purple aluminum center mount rs4pro2 $30.00
hpi pullstarter one way 12r $10.00
hpi pull starter (no one way bearing) $14.00
hpi one way bearing $14.00
hpi mount set micro rs4 $3.00
hpi mip shiny cvds rear nitro rs4mt and rs4mt $20.00
hpi heavy duty differential shaft $4.00
hpi heavy duty 13 tooth final gear (p1x13T) nitro rs4mt $10.00
hpi gearbox/bulkhed set savage .21 $8.00
hpi front rear shock tower sprint $2.00
hpi front axle nitro rush $3.00
hpi flywheel $6.00
hpi diff case nitro rs4mt $3.00
hpi cylinder and piston set for 12E 12E $30.00
hpi connecting rod (70-75) $12.00
hpi clutch bell 13/20 tooth 1m (nitro 2 speed) $5.00
hpi bumper (front and rear) sprint rtr $3.00
hpi ball bearing 10x15x4mm $10.00
hpi axle 5x32mm $4.00
hpi aluminum exaust header black nitro 3 $10.00
hpi 2 speed seconed gear set 39/18 tooth $8.00
hot bodies steel rear universal swing shaft 48mm hpi rtr 3 $15.00
hot bodies stainless ventilated brake rotor set nitro 3 $30.00
hot bodies aluminum rear arm set hpi rtr3 $15.00
gs racing servo saver purple fatuba $4.00
gs racing servo saver (yellow) fut/fma $4.00
gs racing knuckle arm left storm $15.00
gs racing 90 degree press fittings burgundy $2.00
gs racing 4mm/8-32 aluminum countersunk washer burgandy $2.00
gs racing 4mm/8-32 aluminum contersung washers purple $2.00
gs racing 4mm flanged aluminum locknuts purple $3.00
gs racing 4mm aluminum locknuts purple $4.00
gs racing 4mm aluminum locknuts burgandy $4.00
gs racing 4mm aluminum locknuts blue $4.00
gs racing 3mm aluminum locknuts burgundy $4.00
gs racing 3mm aluminum locknuts burgundy $3.00
gs racing 3mm aluminum locknuts burgandy $4.00
factory team threaded shock body .89 w/collar hard adionized tc3 $15.00
factory team red springs 22lbs tc3/ntc3 $3.00
factory team rear arms carbon b4 $5.00
factory team rear a-arms carbon b4 $6.00
factory team green spring 12.0 lbs tc3/ntc3 $3.00
factory team full graphite tc3 (needs screws fell out the bag) tc3 $40.00
factory team front shock tower carbon fiber laminated b3 $8.00
factory team front blue titanium turnbuckles ntc3 $15.00
factory team front blade roll bar ntc3 $30.00
factory team blue machined motor adjustment cam tc3 $18.00
factory team blue aluminunum vcs macro shock body w/cap $10.00
factory team blue aluminum blade bar mount ntc3 $15.00
factory team blue aluminum battery strap (2 of these) tc3 $15.00
factory team black cylinder head AE15 $28.00
factory team 1/10 springs gold 12.0 hard for vcs micro shock $1.00
ergo upper see saw arms $30.00
dynamite side exaust manifold ntc3 $10.00
dynamite set up wheel 1/8 scale buggy $30.00
dynamite pull starter complete 12s/12spd $15.00
dynamite precision droop gauge w/blocks $15.00
dynamite crankshaft locking tool $6.00
dynamite 90 degree directional pressure tap $2.00
duratrax upper arm set rear ax/nq $7.00
duratrax universal dogbone axle 95mm mbx $28.00
duratrax turnbuckle upper mst $3.00
duratrax turnbuckle 5x60mm (2 of these) ax/nq $8.00
duratrax timing pully 18t str force gp $6.00
duratrax tie rod turnbuckle tq $1.00
duratrax suspension arms odst $5.00
duratrax suspension arm mount (2 of these) odst $1.00
duratrax suspension arm front (3 of these) sfgp $2.00
duratrax spur gear 60t two speed odst $2.00
duratrax spur gear 52t metal mmt $8.00
duratrax spur gear 52t (2 of these) mst/mbx $4.00
duratrax spur gear 50t steel tq $25.00
duratrax spur gear 44t steel tq $25.00
duratrax shock tower front (2 of these) mst $2.00
duratrax shock tower front (2 of these) evst $2.00
duratrax shock set rear str force gp $10.00
duratrax shaft wheel mst/mbx $5.00
duratrax shaft wheel mst/mbx $4.00
duratrax screw pin arm (3 of these) mst/mbx $3.00
duratrax round head s/t screw 2.6mml(20) $2.00
duratrax rear suspension arm sfgp $2.00
duratrax rear shock tower (2 of these) sfgp $2.00
duratrax main gear 51t steel ax/nq $28.00
duratrax hub rear ax/nq $10.00
duratrax hub rear aluminum blue evst $25.00
duratrax hub carriers sfgp $2.00
duratrax hub carrier aluminum purple evst $25.00
duratrax hub carrier (2 of these) mst/mbx $4.00
duratrax heatsink head black torq .21 $30.00
duratrax gear case mst/mbx $5.00
duratrax front wheel hub front aluminum (3 of these) mst $6.00
duratrax front upper arms tq $15.00
duratrax front suspension arms tq $15.00
duratrax front brace evst $1.00
duratrax flywheel with spacer ax/nq/tq $12.00
duratrax engine clutch nut (2 of these) tq $3.00
duratrax drive washer mst/mbx $2.00
duratrax drive gear assembly double shift tq $20.00
duratrax dogbone rear tq $4.00
duratrax dogbone rear 92.5mm ax/nq $8.00
duratrax dog bone center rear 90mm ax/nq $4.00
duratrax differential rebuild kit evst $4.00
duratrax diff ring gear 50t tq $25.00
duratrax diff pinion 8t tq $18.00
duratrax diff joint $5.00
duratrax clutch shoes (2 of these) ax/nq/tq $5.00
duratrax clutch bell gear 16t 2-speed tq $8.00
duratrax bulkhead front mst/mbx $2.00
duratrax brake pads (2 of these) tq $3.00
duratrax brake disks ax/tq $6.00
duratrax brake disk tq $3.00
duratrax brake disc $5.00
duratrax bearing set tl-01 $35.00
duratrax ball ends large ax/nq/tq $2.00
duratrax ball end mst/mbx $3.00
connly regulated fuel pump $25.00
conley carb/pump/avm 10mm carb $70.00
brian kinwalds formula 2000 comm drops $3.00
brian kinwald 24tooth bk pitch $3.00
bout 20 misc glow plugs $3.00 each
hpi belts 139t 5.5mm have 2 of these 5.00 each
robinson racing rs4nitro super tuff spur 44t 4.00
robinson racing 48p 20t pinion gear 2.00
hpi heavy duty 38 tooth final gear (p1x38t) i have 4 of these 20.00 each they sell for 35.00 if anybodys intrested in anything please lmk asap i really need to get rid of these parts
btw the last thing the final gear or whatever is for a hpi nitro rs4mt
email me at [email protected] if u are intrested in anything.everything is 50% off the retail prices or more. everything is new and in mint condition. I'm needing to get rid of this stuff as soon as possible cuz i need the room and i need parts for my eclipse. i will trade parts for car audio/video/rims or performance parts for a 97 eclipse gs. my aim s/n's are
bizzare6996
witdaquickness66
TMaxx stuff:
Misc other crap:
rs4-mt $25.00
rs4mt $12.00
nrs4 $18.00 each
nitrors4mt $15.00
hpi flywheel $6.00
bizzare6996
witdaquickness66
