Team Associated Monster GT Manual and Parts Listing
WoodiE
Kind of good admin
Administrator
Lexington, KY
Team Associated Monster GT Manuals
Associated Monster GT Parts List
#2208 - Large Hood Pins
#6299 - 1/8" Small E-Clips
#6332 - Body Clips
#7725 - Fuel Line 3"
#25025 - Fwd/Rev Clutch Housing
#25026 - Fwd/Rev Clutch Hub Assembly
#25030 - Shifting Lever Fork
#25047 - Brake Cam and Hardware
#25051 - Front/Rear Drive Input Cup
#25056 - Drive Cup Set Screws
#25058 - Assembled Shocks
#25059 - Assembled Shocks
#25060 - MGT Shock Body and Cap
#25061 - Shock Rebuild Kit (2)
#25069 - Shock Accessories/eyelet
#25070 - Shock Mounting Hardware
#25074 - Fuel Tank Accessories
#25075 - MGT Fuel Tank
#25076 - Fuel Primer Pump
#25080 - Diff Pinion Gear and Shaft
#25081 - Assembled Differential
#25082 - Front/Rear Transmission Case
#25085 - Diff Outdrives and Gaskets
#25093 - Manifold O-Ring, Coupler and Outlet
#25101 - MGT 8.0 Chassis
#25105 - Front/Rear Upper Arm Mounts
#25106 - Front/Rear Transmission Mounts
#25107 - MGT Upper Suspension Arms
#25108 - Chassis Guard/End Cover
#25109 - MGT Lower Suspension Arms
#25110 - MGT Hinge Pin Set (8)
#25112 - Steering Block/Hub Carrier
#25113 - Pivot Ball
#25116 - Axle Bearing Spacers
#25117 - Axle Pins
#25120 - Front Steering Turnbuckles
#25121 - Turnbuckle Eyelet and Balls
#25122 - Rear Toe Turnbuckles
#25125 - Bellcrank Plastic Parts
#25126 - Bellcrank Post and Bushing
#25127 - Bellcrank Hardware
#25128 - Front Skid Plate
#25134 - Rear Skid Plate
#25135 - Front Shock Tower
#25136 - Rear Shock Tower
#25137 - Pivoting Body Mounts & Post
#25139 - Rear Clip & Flag Mount
#25140 - Rear AE Flag & Post
#25146 - Flywheel Collet
#25160 - Radio Tray
#25162 - Servo.Saver XP/Futaba
#25163 - Servo Horns
#25164 - Forward/Reverse Shifting Linkage
#25166 - Servo Saver Hitec
#25167 - Servo Saver JR/Airtronics
#25180 - M3x8mm button head phillips
#25181 - M3x10mm button head phillips
#25182 - M3x12mm button head phillips
#25183 - M3x14mm button head phillips
#25184 - M3x16mm button head phillips
#25185 - M3x20mm button head phillips
#25187 - M3x14mm button head hex
#25188 - M3x20mm button head hex
#25189 - M3x22mm button head hex
#25190 - M3x14,mm socket head hex
#25191 - M3x18mm socket head hex
#25192 - M3x20mmsocket head hex
#25193 - M3.5x10mm socket head hex
#25194 - Engine Mount Screws, MGT
#25196 - M2x8mm flat head phillips
#25198 - M2.6x16mm flat head phillips
#25199 - M3x8mm flat head phillips
#25200 - M3xl0mm flat head phillips
#25201 - M3x8mm FHH
#25202 - M3x10mm FHHS
#25203 - M3x12mm FHHS
#25204 - M3x16mm FHHS
#25205 - Body Post Mount Screws
#25207 - M3xl0mm BHPTS
#25208 - M3x23mm button head phillips
#25209 - M3x32mm button head phillips
#25210 - M3x30mm button head phillips
#25211 - M3xl0mm button head hex
#25214 - M2 Nut
#25215 - M3 Locknut
#25216 - M3 Locknut W/Flange
#25218 - M5 Locknut
#25220 - Washer 5x12x1
#25224 - M4x4mm Set Screws
#25225 - M3x3mm Set Screws
#25230 - 2mm E-clips
#25231 - 2.5mm E-clips
#25232 - Lock Washer
#25236 - 8x16x5 Ball Bearings
#25237 - 5x10x4 Ball Bearings
#25238 - 6x12x4 Ball Bearings
#25242 - Washer 3x8x1
#25243 - 5mm E-clip
#25245 - M2.6x12mm flat head phillips
#25247 - Radio Tray Clips
#25650 - 3x20mm button head phillips
#25651 - Brake Shoes & Screws
#25652 - MGT 8.0 Brake Disc
#25653 - M3x35mm socket head hex
#25654 - M3x18mm button head phillips
#25655 - Diff Gears MGT 8.0
#25656 - Diff Housing
#25657 - Diff Spur, MGT 8.0
#25658 - M3x6mm SHCS
#25662 - Rear Drive CVA
#25663 - MGT 8.0 2-Speed One Way Hub
#25664 - MGT 8.0 2-Speed Main Gears
#25665 - 2-Speed Clutch Housing
#25666 - 2-Speed Clutch Hub
#25667 - MGT 8.0 2-Speed Shaft
#25668 - Forward/Reverse Drive Gears
#25669 - Center Transmission Shim & Clip
#25670 - Forward/Reverse Shifting Gears
#25671 - Forward/Reverse Main Shaft
#25672 - Reverse Idle Gear & Shaft
#25673 - Reverse Gear/Shift Fork Mount
#25674 - MGT 8.0 Bevel Gear
#25675 - MGT 8.0 Slipper Shaft
#25677 - MGT 8.0 Slipper Hardware
#25678 - MGT 8.0 Spur Gear Hub
#25679 - Slipper Friction Ring
#25680 - MGT 8.0 Slipper Pad
#25681 - MGT 8.0 Slipper Hub
#25682 - Drive Pinion Shaft
#25683 - 2 Speed Pinion Gear
#25684 - Center Transmission Bracket
#25685 - Center Transmission Case
#25686 - Center Trans Pins
#25687 - MGT 8.0 CVA
#25688 - Drive/Brake Hub
#25689 - Front CVA Rebuild Kit
#25690 - Front Drive CVA
#25691 - Rear Drive Output Cup
#25692 - Rear CVA Rebuild Kit
#25693 - Front/Rear Bumper Extensions
#25694 - Front Bumper & Brace
#25695 - Rear Bumper & Brace
#25696 - MGT 8.0 Wheelie Wheel
#25697 - MGT 8.0 Wheel Hex Drives
#25698 - Universal Rebuild Kit
#25699 - MGT 8.0 Spur Gear Mount
#25701 - MGT 8.0 Engine Mount
#25702 - Muffler Mount Wire
#25703 - Engine Mount Brace
#25704 - MGT 8.0 Gear Box
#25705 - M5xl3mm SHHS
#25706 - MGT 8.0 Roll Bar
#25707 - MGT 8.0 Roll Bar Mounts
#25708 - Throttle/Brake Linkage
#25709 - MGT 8.0 Bearing
#25710 - 5x11x4 Ball Bearing
#25711 - M4x8mm Screw
#25712 - MGT 8.0 Decals
#25713 - M3xl0mm SHCS
#25714 - 8x5mm Washer
#25715 - MGT 8.0 Diff Shims
#25716 - MGT 8.0 Muffler
#25717 - MGT 8.0 Header
#25718 - MGT 8.0 Flywheel
#25720 - MGT 8.0 Clutch Shoes
#25721 - Clutch Spring 1.0mm
#25722 - Flywheel Shim
#25729 - MGT 8.0 Filter Elements
#25730 - MGT 8.0 Air Filter
#29117 - Batter Holder 4-cell TR402A
#31541 - M3x6mm FHCS
#89218 - Washer 3x8mm
#89231 - 3mm Lock Washer
Team Associated Monster GT Mods
