I scrambled to finish my second Dragonoid before the race this past weekend at the Versus Monster Trucks show in East Waterford, PA, and got it done so that I could enter the "twins". This also meant that I had zero time to get any practice in, and dial in either truck, or test the new one much other than "it moves". It turned out to be both good and bad. Good that I got the second truck done. Bad that I didn't get to test and practice.
The race day was amazing. Kyle Taylor did a great job organizing and running the event, and we had a pretty good crowd watching us from the grandstands. A couple of races the PA announcer from the full sized truck event called them. There was a full bracket of trucks thanks to some of the guys bringing a bunch to enter. Everyone was extremely nice, helpful, and I think all had a great time...despite it being...HOT out. I was greatly appreciative of Kyle allowing me to enter despite being nitro powered and his club being all-electric. I would love to see more races that allow nitro in the pro mod classes - especially with the new nitro Kyosho USA-1 coming out soon. There was certainly some interest and fascination with my trucks(especially from the kiddos in the grandstands who love Bakugan Dragonoid).
The track was the pit area between the grandstands and full sized truck track, isolated by concrete road barriers. Really a cool, great idea to have it run there. It was however, rather rough, dry, and loose. Early on we got a few practice hits in, and it was clear that one, getting around the track was key, and two, there were going to be a lot of broken trucks. Mine included! At some point during warmups, my main truck lost a pin in it's front driveshaft's cv joint. Tiny e-clip broke or fell off. Probably from a flip on a jump, but not really sure. Either way, instead of getting my steering dialed in, and some time behind the wheel of both, I spent most of the morning trying to fix that shaft. Unfortunately I used my spare shaft on the new truck, lol. In the end I took a 1.5mm metal rod, bent the ends to make a little pin. Certainly not ideal, and I was gonna have to baby that thing some, but I figured it was better than running in 2WD.
In the qualifying rounds, I had a horrendous showing. The main truck's run ended instantly in a DQ when I missed the first ramp completely. My wife took video, which I analyzed, and I had the ramp lined up perfectly on approach, and as I gave it some gas, the truck veers sharply to the left. I didn't realize what happened, but closer inspection indicated that my front steering was somehow completely out of alignment, so it looks like it was a combo of me letting off the wheel after it was lined, and when giving it gas getting huge torque steer/slippage. My second truck fared only slightly better. Video showed on takeoff that the rear kicked out to the left in the loose dirt, and I overcorrected and got pretty far out of line with the ramp, got it back lined, but then wrecked on the jump. Not a good showing for me, or nitro! (I did zip around a little after wrecking so the kids in the stands could see their favorite truck fly around, lol).
The elimination round didn't start off much better. I did my best to fix the steering on the main truck, but it still wasn't right, and the truck was all over the place due to that and traction loss. The Firestorms just didn't have enough bite on this surface. I was down to my last chance, now with my backup truck, which incidentally, is setup with no rear steer, and was clearly not dialed in yet. My luck was about to change though. This time, I got a really good, straight launch, hit the ramps and corners clean, and got around the track for the win. Monkey off back. The next round I had another good run, and that got me into the quarter finals. Unfortunately here I got a little too throttle happy, got all over the track, and while I did manage to get around, I hit pretty much every turn marker, and had a flip on one of the ramps(though it landed back on it's feet). My racing day was done, but man that was a thrill, and I was happy to make it as far as I did.
Other than the driveshaft and the steering problem, I had no mechanical failures despite numerous crashes and the rough track. Given the number of broken trucks this day, that in and of itself was a minor victory, and a testament to the strength and durability of these chassis. Judging by some of the conversations I was having, I think Kyosho is gonna sell quite a few of these USA-1's next month
The steering issue btw, turned out to be a rod end that got stripped. I also realized that my steering bell crank mounts were still too sloppy, they really got exposed on this track. So it was time to come up with something else.
First idea was to try axle mounted servos. Because it's a 5-link suspension with a panhard bar, they would have to mount with the arm facing towards the inside, and realistically I just couldn't see any good way to do this. I really want to keep this 5 link setup. It's unique, and precise, very little slop at all. So I saw a guy that had modeled and 3d printed a pretty heavy duty looking steering crank mount, and decided to give that a try with some modifications. First, his version had a very long bar, and I wanted to shorten this up some. I also wanted to use 8x5mm bearings for the bell crank to pivot on. So I made my changes, printed them out. I also CNC'd a CF bell crank.
I put it together, and got it set up on the front (Note, I need a longer M5 bolt yet for the crank pivot).
This bell crank is really tight with no slop of any kind, no flex, should be a big improvement. Also my custom bell crank has four mounting points so that I can adjust steering travel very easily mechanically. That should really help with increasing or decreasing rear steer depending on the track I'm running on. I still may at some point add a second servo for rear steer and control it with a potentiometer even more easily and precisely, but mainly I wanted those bell cranks and mounts to have no slop and no flex.
Eventually I will slowly upgrade the second truck, and mostly likely change it's color/body to something else, kinda don't like having two of the same, plus I want to have proper spare stuff for the Dragonoid. [edit] I had considered using a Predator body, but it's just too small, so going to stick with the Dragonoid, but do it in an "ice" theme.
