Long time, no update, but been busy on this beast and some other stuff for sure.
I finished the body for Camden Murphy, and he absolutely loved it! At .080, this thing is brutally tough, I cannot imagine it breaking unless colliding with something at an extreme speed. I think for freestyle and bashing, this body is perfect. It's waaaay too heavy for racing though.
Now he just needs to get his Mad Crusher
As for my truck, I've made two very major modifications with performance in mind. The first thing was to start looking at reducing weight, as I've added probably a pound or more overall with the axles, swaybars, and suspension parts. The first, and obvious thing is to replace those heavy steel sideplates with CF versions. I decided to make them myself, which minus a mini bandsaw is a little rough, but I was able to do a pretty decent job using my dremel tool.
I probably could have cut out more areas, but I was a little worried about too much flex. I forget the weight savings, but it was at least 1/4 lb. Not a huge reduction, but finally moving in the right direction for once!
The next mod was even more significant. I've been lamenting that the stock 3 speed transmission has zero aftermarket support, and that the clutch bell is too small for any other clutches besides Kyosho's. I had bought a pair of REDS Tetra's that I really, really wanted to use, and I also really didn't like having a trans with multiple speeds for Monster Jam style racing. Really don't like it trying to shift while coming into a turn, and I also felt that first gear was a bit under geared. I'd also like the freedom to change pinion gears to suit different course designs.
So I did some research, and saw a bunch of people simply adjust the trans to skip first, or even second gear. That's actually not a good idea, as the way the trans is designed, it'll wear out very quickly doing it that way. Looking at the thing in pieces, I figured it wouldn't be hard to convert it to a single speed unit. Just needed a few items(four 6mm bearings, three 6mm washers, two 6mm collars. Easy.
This also reduced some rotating mass, and especially with the extremely heavy stock clutchbell(I swear that thing is half a pound, need to weigh it!).
This allowed me to put in my brand new powerplant/drivetrain:
I used an 18t pinion gear up against the 46t spur. Stock is 14t for first gear against the 46t spur. This gives a ratio of 2.5 which is a bit less than the stock second gear ratio of 2.38, but more than the stock first gear of 3.3, which I felt was a pretty good starting point. Best thing is that I have a 14t and 16t bell that I can switch too
Nothing is totally easy though. The engine mounts had to be modified on one side to accommodate the 18t pinion as there is a mounting post squarely in the way of moving the mounts.
A little beveling with a dremel solved that issue.
So I broke in the SH .28 p8 and got to doing a little testing. Whoo boy...
1. The SH .28 p8 is one serious beast. Compared to my .28 p3, well, no comparison. Compared to the stock KE .25, well the p3 was much stronger, so this is just insane. With the p3 I actually had twisted one of the swingshaft dogbones into a pretzel. I decided to replace all of the stock dogbones with CVD's, just to be safe, and also to get rid of another power robbing friction point.
2. With this kind of power, the 18t/46t simply gobbles up ground. It literally just leaps around the yard, it's insane how fast this thing is now. Still has enough top end for Monster Jam style racing for sure. I will need to do some testing vs the 16t gear. I suspect that the 14t gear would make the truck uncontrollable.
3. The REDS Tetra is easily the sweetest, smoothest clutch I've used. Amazing the difference from the stock one, to the Fiorino 3 shoe, to this one. I tried the 3 settings, and concluded that for MJ style racing, the L setting is best, though M was useful. The H was not good for tight course racing IMO, just not quick enough off the line.
So at long last, this project is completed! There have been a lot of tweaks, adjustments, but it's pretty close to the original vision I had for it. My next truck project is a 1/16 version of this, and yes, nitro powered with an SH .07
In the meantime though, I've been working on building my portable MJ race course components, of which I will start a new thread on soon.
