Have the Trx4 Defender and was suggested to me to do a couple of upgrades.
1, change out the steering servo and 2, drop in a brushless motor.
I was looking at the Traxxas 2255 waterproof metal geared servo but was told that was overkill. That the Feetech 35kg servo would be sufficient.
Traxxas servos dont have a very good reputation in general. That one looks like it might be better quality than their much more common 2075 or 2075x servos. The servo you ended up going with is a cheap Chinesium piece of crap imho. Its supposedly about 500oz/in or torque but Id be surprised if it wasn't really more than maybe 300-350oz/in. That being said thats still plenty of torque for that kit. Your stock 2075X servo is only 125oz/in. (Higher is better) The bigger downside to the Feetech imo is that its a super slow servo. its .19sec compared to the already painfully slow .17sec of the stock 2075X servo. (lower is faster). Will the servo work? Sure, but personally Id either put a name brand servo like Savox, Hitec, or Protek. If I didnt have the budget for that then Id look at something like
THIS JX brand servo from Amazon. Cost $45 compared to the $22-$23 that the Feetechs you bought cost but I've used a couple of these now and had pretty good results with them. The one I linked there is about 450oz/in and .12sec speed. I havent used that exact one but thats the one Id use for a crawler if I was going to use a Chinesium brand servo.
It was then suggested that if I was going to put in a brushless motor that I put in the Hobbywing quicrun fusion.
I've read that the Fusion is a great system and the Castle Mamba X/Holmes Hobbies puller pro 2200kv I'm sure would be a great system also. Castle Creations and Holmes Hobbies are well respected brands in the RC world.
I read that it has very strong BEC, not sure what BEC is.
Normally a rigs servos, lights, and any other electronics besides the motor are powered by a
BEC. Now normally that
BEC is internal to the ESC but the internal BECs a lot of times are weak and they typically dont have the ability to vary the voltage output. High end ESCs will have beefier BECs and some will have minimally adjustable voltages but generally a good stand alone
BEC like
THIS 10A Castle Creations brand BEC will be stronger and more adjustable than any internal BEC. It can also be programmed to output anywhere from 4.8-9v although you do have to buy a "Castle Link" in order to program it but those arent very expensive. Sometimes you can find people in forums even giving the Castle Links away because you get a free one when you purchase certain ESCs. You only need one so some people will give their extras away to newer folks that need one. Another ancillary benefit of running an external BEC is it takes the extra strain of running your additional electronics off of the ESC so the ESC only has to worry about powering the motor.
Is this something that is going to cause issues for the stock radio system and/or this other Feetech servo that I would put in?
And if I add a light system is that going to add issues?
A BEC wont interfere with anything. They can be a tad confusing on how to hook them up but if you decide to go that route we can help you get it sorted
