Esc ?
duramax47
Is their anything i have to change with my mamba max pro when i switch from a 2cell lipo and then go to a 3cell lipo, because i have both and wasn't sure if their was some settings that needed to be changed or if i can swap them all day and not worry.
Better make sure that its on auto lipo instead of set for 2s. Good chance its on auto but you better make sure.
Will do. thanks
Default setting is auto lipo so unless you changed it in castle link then you'll be good. Never hurts to hook it up to the castle link just to double check the settings.
Good to know, I wasn't sure.
You should also set the lipo cutoff at 3.2v per cell. Mine was set at 3.0v per cell. Maybe they've updated that since I got mine.
