I Am not too sure what vehicle i am going to use yet. I am thinking of a short course truck that wont really be over 4Kg. I am also trying to hit around the 127mph with the Tp 3630-cm 7000kv 3s with the Mamba Monster 2 and a 45t pinion and a 84t spur. Do you think i could go any faster with the Tp 3640 4700kv with the MM2 or would it be drawing too many amps for the MM2. The reason behind a short course Truck is because i also want to do some bashing with it as well so it is not JUST a speed build. And yes i Definitely NOT put my phone on it trying to record its top speed
Anyway i don't think those apps even work anyway.
One of the biggest things regarding brushless motors and going over 100 mph is torque! The air is pushing hard on the car and the motor needs to power through that with torque. The motor torque is significantly stronger with larger diameter motors. For this reason, anyone going over 100 mph is using 40mm or the 1/5 scale motors (56mm and 58mm). You also increase the torque with longer motors, but I have found diameter seems to produce more torque.
3s is very limiting in regards to power. Also it is worth knowing that higher kv pulls more amps. I know all the top names in speed running and no one runs 7000 kv except for maybe a very light weight on-road car running 2s, or drag cars, which rarely see speeds over 110mph. High KV motors get very hot, very quickly!
A quick note in math for how this all works.
voltage x amps = watts
11.1 v * 300 amps = 3,300 watts
watts / 745.69 = hp
3300 watts / 745.69 = 4.4 hp
If you were to instead run 6s on an Arrma 6s vehicle with an ESC that can output 300+ amps (factory RTR ESCs are generally 100a to 150a)
22.2v * 300 amps = 6,600 watts
6,600 watts / 745.69 = 8.85 hp
I honestly think you should get the
MMX8s esc and an Arrma BLX2050kv motor or the new Spektrum 2050kv motor. Having data logs from the
MMX8s to help you make well educated decisions on what changes to make to the car will be priceless. Without that data you are simply guessing. MM2 esc does not have data logs by the way. Don't bother with the MMX6s esc as it runs hot and has thermal shutdown kicking in all the time.
One thing I can say is that you can spend a small fortune making a SCT like the Slash 4x4 into a speed car. It is far cheaper to start out with an Arrma 6s vehicle. The other thing worth noting is that short wheelbase cars are very unstable at high speeds. Cars like the typhon and SCT vehicles. Your best money spent for going fast would be something with a longer wheelbase like a Kraton, Talion, Limitless, Infraction....
The Arrma cars have a very solid spring/shock setup, heavy duty double a-arms. Aluminum chassis for reduced flex.
Also differentials are a consideration. Some brands differentials just don't hold the power. Hobao is another solid option for speed use.
Having a dual purpose RC car just does not work. It would have completely different suspension, tires, gearing, aerodynamics. They are best left as two separate RC cars.
