I'm assuming you meant to say the the 3080 is faster on 4S than the 3840 on 3S with the same gearing? If thats the case go that route then cuz the lower KV motor will be more appropriate for bashing too.yeah i probably would do that if they didn’t come back to me but they did and they said it was a typo and they changed the max voltage of the Tp 3650 3080kv to 19 volts so 4s. So i think i will probably go with the 3650 3080kv because according to a speed calculator on the same gearing the 3650 3080kv is about 10kmh faster than the 3650 3840kv on 4s and it will have more torque because it is on 4s so more bashing and better speed running potential.
More wattage does typically mean more torque and horsepower than a lower wattage motor if all else is equal. It also means more amp draw and more heat but you can compensate for that with gearing.Also i calculated the max watts (According to my calculations Tps max watts are wayyyy of by 1000 to 1500 watts if their max amps are right but i can’t be bothered to chase it up with them because it ain’t gonna change anything.)
and it should have around 500 watts more power on 4s than the Tp 3650 3840kv on 3s. Also does more watts equal more torque or more horsepower?
Just because its designed to hold a 1/10 scale motor doesn't mean you can't put a 1/8 scale motor in it with some modification. Thats what I did to my 100+MPH Rustler in order to get it to break 100MPH. I'm not saying all kits can be modded in this way but a fair number can. That of course is entirely up to you though. The bigger scale motor would be better for speed runs but depending on what kit it is may not be good for bashing purposes.well it is because i plan to put it in this RC car that comes with a 550 sized brushed motor so i assumed i can’t go any more in width.
Its not so much hesitation you get at very slow speeds with sensorless, its more like jerkiness. Its not that big of a deal though although the sensored motors are buttery smooth at very slow speeds. To me its one of those things where sensored is nice to have if you can have it in the kit you're trying to build but isnt a deal breaker if you're trying to use some specialty motor that only comes sensorless.plus i am going to run a sensorless system (because i don’t think the TP 3650 3080kv is sensored) i don’t want any start up hesitation so it is about the biggest motor you can get with probably no to hardly any start up hesitation because i am pretty sure the wider the can the more start up hesitation you have. (also weight is starting to become a problem so i don’t really want a heavier motor)
If you can swing it, its definitely got more options. With a 1/10 scale motor I'm pretty sure Amp draw wouldnt be a problem for either ESC.It would be nice having data logging features and there is a few other really good features that isn’t on the mm2 and it fits the budget and i would imagine it will be able to handle more amps so less heat and more life and more motor performance.
Look at the rocket brand high rpm fans. They come is a bunch of different sizes from 30mm up to at least 50mm. Any motor heatsink/fan mount for a 1/10 scale should work just make sure you get a fan(s) that are the same size as the mounting holes on the heatsink.also would any one be able to recommend a good big-ass high voltage fan that would be good with the Tp 3650 3080kv that could plug right in to my spektrum receiver
