ChuChu
Hi,
Few questions to DT-03 suspension setup. I will use CVA shocks ( without holes, solid plate), Hop Up Sway Bars and NiMh battery.
I read a lot and it is obvious that rear end is super heavy, especially with NiMh battery.
1. In wishbones I see two same holes for shock mount. Can I choose in which one I will mount or I should stick to manual?
2. By default there is Soft oil for dampers. Is it worth to use Hard in rear shocks?
3. Sway bars. Any advice how to start? Soft front/ Hard rear?
Any other tips? I will use it to drive around just for fun. Probably most on gravel and tarmac.
