Shaking off the rust, again, but literally. Well, on the slash it was
(I haven't been in over almost 2 months)
New layout at the clay track. Something new and interesting. The back lane near the driverstand is the new straight, and the old "straight" is now split up and some new table top wood jumps. Since the new straight is the back straight now I feel like it is slightly longer so you get more speed. How in the world is my 2wd (17.5) faster speed wise down the straight than my 4wd (13.5)? I have no idea. Lol. Met some new people, racers, and helping out a new racer as well with her car. May not be a packed race day with more people but the smaller club race days make it more fun.
2WD: Been running like a champ all day up until the A Main where I got a DNF since my axle popped out of the outdrive somehow. not sure how since the ball cup was still on. I guess it flexed too much when landing. (But I lost drive in the sweeper...
weird). Tires, are questionable. Grip was actually pretty decent in the morning but when Q3 rolled around I was sliding and it turned into a drift car but in the mains I learned and got over on how to manage and control it better with slide-y tires. Like idk which race it was but I sauced the tires right before the race. my 2 check in laps grip was great, but as soon the clock started, grip wasn't there, like the compound worn off quickly. Can't complain as I'm running on nearly/probably 10yr old discontinued now ProLine Primes that are shedding rubber chunks everywhere.
Yes planning on getting new tires soon. Just trying to hold out and get my moneys worth out of every tire. Biggest things of the day was Q1 (moved to 3rd from 4th), Q2 (moved from 2nd to 1st), stayed consistent in the B main and got that bump. (shoutout to one of my buddies for lending me a spare pack for the A since I didn't have a spare one charged) Fastest lap of the day was 18.7. Average consistency of 86-94%.
4WD: Good as always. I know how to drive on wheeler. Can seriously wheel around. Nothing much to say other than ole worn out tires. ESC fan blew. blade just hit the eject button. have 1 spare fan and ill wrap a zip tie around and hopefully it will work. I have a worn (warped) out block on the front left, per usual AE part quality. Been beating on that block for the past 2 race days with the same issue so I'm not worried until it falls apart. Front left tire came unglued just slightly in Q3, didn't bother to fix it because why? Lol. Also the front right hinge pin for the hub into the arm kept backing out, while that set screw was super right. wonder if I need a new pin, new hub, new arm or new set screw.? Biggest things of the day was 4th to 1st in Q1 and 3rd to 2nd in Q2. Fastest lap of the day with this car was 16.8. Average consistency of 88-92%.
Practice: Finally got to test out the Reflex on the track since i've been mostly running it in the street, now its mostly worn down to slicks, although the stock tires are quite a hard compound. It hooked up pretty good, granted I sauced the tires the night before, not on race day. The overall truck is super sensitive to brake inputs when trying to land from a jump causing you to flip/crash. I feel like its just because its 4wd on a shorter wheelbase that a truggy shouldn't really be on, plus it isn't really that wide. Mini B: Testing out the new rear slicks, which these were just stock BK Bar tires burned-out to slicks with only 2 times ran over with compound, it hooked up WAY better than my old slick-ified Jcon ellipses. Much better around the track with not sliding out in not that aggressive turns. Rustler and Pro4 been running the same setup so those are always dialed
. Slash, before, I added some preload in the front to make it more stiffer, helped alot with keeping it stable and not "dipping in" in aggressive turns. Grip with the OG Smoothie SCT Greens is also hooked.
Also, first track day with the G-E-N-S A-C-E D300 charger. Locked in with that extra wattage
View attachment 245007View attachment 245006View attachment 245009View attachment 245008View attachment 245005View attachment 245004
