Update & solution
Okay guys so I've iinvestigated some more with the front wheels not wanting to spin freely.. went as far as popping out the bearings, cleaning them and greasing them putting then back in
And guess what, didn't do anything for me..well except they are buttery smooth if not tightened down!
I then went ahead and tried something, took off the rear side switched bearings around taking the back to the front and still binding!
I then looked at the hex cap & pin intensely and saw something suspicious.....
I gave it some thought and saw (the lip) was a bit squashed and possibly a result to the binding....
The picture below shows arrows pointing right at (the squash) the inner being deeper as that sits against the inner bearing, but the higher point seems to be rubbing the casing between the outer & inner rings of the bearing case!
See picture
So I quickly dug up my old redcat 10 scale crawler (parts truck) took the hex cap off (being the same size) gave it a go
It worked!! We're up and running silky smooth!!
First thing I took notice to is a slightly different design as the center lip that meets the center bearing ring is smaller which is good because it sits right and tight against it!
See picture
I'm glad it worked out! Thanks you guys for the comments and reaching out! Now the only question is, do they make these hex inserts in metal or perhaps aluminum?? So these plastic ones don't serve as a squash plate all the time
Hope this could possibly help others if one ran into binding issues like so..
