Controller Range issue :(
Jamama
Hi guys,
I have a Ansmann Virus 3.0. I absolutely loved it at first... since I took over to my local park about a week ago the car will now only get to about 20 feet and all controls will cease to work. :(
All help will be appreciated.
Thanks,
Jake
check the antenna for damage. Especially the last inch or so of it if its a 2.4Ghz system.
Yh its 2.4ghz... I did run it into a small puddle by accident, it is meant to be "waterproof".
I shall have a look at the antenna tonight when i get in :)
Id take the RX case apart and check for water...most of those so called waterproof setups aren't really waterproof as much as they are water resistant.
I do remember looking in there actually... I don't remember seeing any water at all... But I did spot a very, very small amount of some weird pale greenish residue around the cable end of the battery connector?
Looks like I'm going to be replacing the connectors then :P What connectors do you recommend and if possible where to get them
Thanks again
Your standard RXs use futaba connectors. I usually order mine off of ebay but you should be able to get them from your LHS or any online retailer.
