Batterys
solly69
Australia
I am interested in getting a battery pack for both my control and reviever in my car
i have no clue about what to get so if some1 could point me in the right direction it would be great
I have a ACOMS Technisport 2.4gz system and plan on racing soon so i want something that will hold its charge for a long period of time
Ebay or Towerhobbie links would be great :)
The rx pack will be dictated by what ride you have. You'll want a 5-cell (6.0v) pack for the rx. Whether it's a hump pack or flat pack will be determined by the amount of room you have to install it in.
As for the tx, I'd just grab the highest mAh NiMH AA cells that you can find. It would be possible to convert it to 10-cell Sub-c, but why bother rewiring the transmitter to use them. Yes, it's true you lose 2 volts by using 8 AA batteries. But it doesn't seem to have a big effect on use. And as long as you get high mAh cells, they'll last a long time between charges.
Cheapbatterypacks.com They are great guys. They can custom build packs to suit your needs at a very good price. Better than Tower most of the time. In my 3PKS I actually use a 9 cell pack with gives me 11.25 volts (12.25 at fullcharge) with 2500mAh. It gives me several days of running before recharge.
i have no idea what you are talking about
batters confuse me
links to suggested packs... ill post a pic of the bottom of my controll so use guys know what it is couse I'm so lost here :S
OK, let's see if we can break this down for you.
There are different types of batteries. NiCd is Nickel Cadmium. They were generally the first widely available rechargeable batteries. They work fairly well. They do suffer from issues like the "memory effect" where if you don't consistently discharge them before recharging them, they won't fill to capacity and their reliability diminishes. NiMH is Nickel Metal Hydride. These are more reliable. Less prone to the memory effect. Probably the most widely available conventional rechargeable on the market. LiPo is Lithium Polymer. These are lightweight, high capacity packs that deliver a lot of punch and are really awesome batteries. They are used a lot in electric aircraft and helis. And alot of guys are now using them in crawlers and other RC cars. They are a bit tempermental in how they're charged and discharged. They need specialized equipment to charge them appropriately or they have this nasty habit which I won't mention here.
Typically, you can find NiCd and NiMH batteries in the standard AA format which is the standard cell to use in your transmitter battery holder.
A sub-c battery is the short, fat battery that is usually used in an RC car pack. Like a 6-cell stick pack for a TC or electric MT. Those have the same properties as the AA but are a bit more robust and can come in higher capacities.
Capacity is measured in mAh which stand for milliamp hours. That is a measure of how much power they can put out over the space of an hour. So the basic principle is that the larger the mAh number, the longer the batteries will last between charges.
Now, for the receiver pack, a lot of companies make packs that will drop right into your ride. They are usually pre-assembled. A flat pack has the batteries side-by-side. A hump pack usually has 3 batteries side by side on the bottom with 2 batteries side by side on top so they look like a little pyramid. That's why it helps to know what kind of car you're putting the batteries in so we know if a hump or flat is a better pack.
OK, that's some basics. Any questions?
ok i surprising understood all that and from what i got from it because i run nitro its fine for me to just stick with my NI-HM 2600mAh Singular batteries in my receiver and radio??
That would work well. There is one point I want you to consider, though. Using standard alkaline batteries, your radio's receiver typically runs on 6.0 volts (4 batteries x 1.5 volts each). If you use 4 rechargeable batteries, it will only be running on 4.8 volts (4 batteries x 1.2 volts each). It will still work fine. However, the servos will run slightly slower with a bit less torque because the voltage is different. That's why I recommend getting a 6.0volt rechargeable receiver pack when you can. What kind of car is it?
A Robitronic Protos
I have done a review on it if you dont know what it is and it has pictures
i also run a ACOMS TECHNICSPORT 2.4gz radio system
i want to start racing and dont want to be let down by batteries 2wards the end of the race so I'm trying to prepare myself
yea thats the battery box
thankyou ill check it out
what about for my radio
thankyou for your help
i do have 1 more question
i need a charger for that hump pack haha what 1 do you recomend?
Depends what your budget it.
Higher end? Electrifly Triton or DuraTrax Ice.
More budget? Try one of the MRC SuperBrains. They work well for what you need.
well whats the diffrence between a dear charger and a cheap 1??
I just thought some took longer :S
Like i said I'm clueless at electronics
