hi guys, been some time since i`ve got my elec. truck out to run. have a charging/discharging question.
i have been running an e-maxx with a 6s castle speed control. using 2- venom 7.4v 2s 5000mah 50c batts to run.
every time my run is over the one battery reads around 6.7 to 6.8v & the other ( and its the same one all the time)...
always has a voltage of 7.4 volts or so. why is the same battery always around 7.4 & the other around 6.8?
these have always been charged on a traxxas ID charger. the venoms came with a traxxas gen2 battery adapter so it would fit
in the ID charger. even though they can't be "i.d.`d" since the adapter does not have the balance wires built in like the real
traxxas batteries, the charger can be put in "advanced mode" to charge the batteries manually. ( with the balance plug in the balance port)
the charger charges these batts @ 1A automatically and then after about 2.5 hours or so it goes to 2A for a while longer.
but its all done auto & balances at the same time.
could someone explain what is going on with the differences in the discharge.
thank you. ( if you need further info please ask)
