As long as it's not a sensored set up, yes.
In RC brushless ESC (Electronic Speed Control) and motor combos, the difference between
sensored and
sensorless setups is in how they track the motor's rotor position:
- Sensored Setup: A sensored motor has built-in sensors that provide precise information about the rotor's position to the ESC. This allows for smoother startups, better low-speed control, and more precise throttle response, making it ideal for racing or applications that need high accuracy, such as crawling.
- Sensorless Setup: A sensorless motor relies on the back electromotive force (EMF) generated by the motor to determine rotor position. While simpler and more robust, sensorless setups can have rough startups and less precision at low speeds but perform well at high speeds, making them suitable for bashing or high-speed driving.
In short:
sensored is smoother and more accurate at low speeds;
sensorless is simpler and better at high speeds. Most modern ESC & Motor combos (like Tekin, Castle, & Hobbywing) switch to a sensorless mode once motor RPMs get to a certain point, so you get the best of both worlds.
