If the center is melting out, then your having excess slipper slippage. I had that problem when running too tall of gearing after installing a LRP28S3 in my savage. With my old engines and lower gearing, I ran 10+ gallons on the same 52T spur! I still have it in my tool box somewhere. It's all beat up, but still no teeth missing and spins true.
As soon as I got 3/4 the way through break-in with the LRP and gearing that I thought would be reasonable (16/47), I knew I was about to have problems...
I ended up running 16/49 gearing and relatively normal sized MT tires/wheels. Going from 47T to 49T made all the difference in the world.
With 47T and the slipper spring fully compressed, it would be fine in 1st gear, but as soon as it shifted into 2nd, the engine had more torque than the slipper could deal with and it would start slipping. Within a few minutes of running it kind of hard, it was slipping constantly. As soon as I geared it down 2T, roughed up the slipper pad and washer again, I haven't had an issue since.
