can i run a steel spur gear with a stock hpi clutch bell just for a few tanks?
pelicanprentice
RCTalk Racer
i picked up a new steel spur gear for my savage x and i wanted to test the gearing for a tank or two before i upgrade my clutch bell. this is regarding the savage x. the clutch bell i have is the stock hpi metal one. i read that when running steel spur gear you are supposed to upgrade the clutch bell to a steel/hardened clutch bell otherwise the spur will damage the clutch bell or whatever. i wanted to ask if its possible to run a few tanks atleast? i dont care if the clutch bell goes to poop at the end of the run, i just wanna be able to test the gearing, for example if i like how it runs then ill buy a hardened clutch bell with the same amount of teeth, however if i think i want more tq then ill buy a smaller hardened clutch bell
hope that makes sense!
thx
You can run it but I personally dont suggest using a metal spur gear. The spur gear is plastic for a reason and that reason is so it can be a cheap point of failure if you have other issues in your transmission/drive line. If you have a problem soemwhere in the drive line its better to strip a $5 spur rather than potentially make some issue in your, lets say, transmission worse. As long as theres no issues with anything in the drive line a plastic spur will work for a long time before needing to be replaced. Just fair warning.
thx
perfectly fine.
thx
in short yes you can, it will tear up the teeth rather quick on the clutchbell, but it should last a few tanks, just with noticeable wear on it.
