3.3 sleeve replacement problem.
vtrang
I just replaced the sleeve and piston on my 3.3 engine for my tmaxx. The problem is when the engine is at top dead center it gets really stiff and gets stuck. It's so stiff that the ez start will not turn the engine over. Is this normal for a new sleeve and piston? I don't see what the issue is. The connecting rod isn't getting caught up in the crank case at all and I put plenty of oil on the piston and inside of the sleeve.
If you took out the piston and sleeve, you would notice that if you pushed the piston into the sleeve, it would get stuck.
I forgot the term for it, cylinder pinch maybe, but yeah that's completely normal for new engines. The starter might not be strong enough, that's also normal and my only solution is getting a pullstart. Or you could also shim the cooling head to create a larger compression chamber, but that wouldn't really lower your pinch.
It’s called mechanical pinch. Your sleeve is TAPERED up to the top. You will need to pre-heat your engine to 220F prior to starting it to perform your break-in procedure. This is why the #1 rule in nitro RC is to ALWAYS rotate your piston around to BDC (bottom dead center) EVERY time you shut down the engine. If you do not, you will absolutely destroy it.
It’s because it’s new. The pinch is always extremely tight on a 3.3. Lots of people complain about the motor but, of OS, dynamite, and the 3.3, the Traxxas has the tightest pinch when new.
You should always preheat the motor on any nitro. But, it’s mandatory on a new 3.3 or it will get stuck. Expect that for at least the first 8-10 tanks. Then after being broke in, you’ll likely be able to start it cold with the starter.
But, I wouldn’t. It’s just hard on everything. Plus the heat makes it stay running after the first start on a motor that’s not warmed up. I will guarantee you that if you don’t preheat the motor, and just start it and take off, you are going to be doing the walk of shame to restart it once you get off the trigger after the first decent burst.
I apologize. I didn’t read anything but the first post before I commented. And, I didn’t realize peepee-head littlemotor had commented at all. Took a while to figure out what the meme even meant until I saw I was ignoring his content and clicked on the link.
I’ll do better in the future.
On a positive note, it did give you two a chance to slob knob on one another.
It’s a DISCUSSION forum dude… Relax. We rib each other all the time… I bet you are TONS of fun at parties.. 🙄🤣🤣🤣
Maybe you should take your own advice.
I can see now you need to be handled softly. I’ll be more delicate in the future.
I’ll unignore you too. You need to improve your ribbing game. I can most certainly help you in that department.
Maybe you should READ before you post, and then get all offended my friend… Seems you find yourself in that predicament often, but fail to learn from it?
Yes-please feel free to educate me in forum etiquette, people skills, and a proper sense of humor; that would be super helpful! Perhaps you could shoot me your phone number, and we could hang out in person too? 🤩🥳😘
Wierd your mind jumps straight to some homo comments.
You got something on your mind over there?
When I logged back in I caught myself Just wandering how your date night with littlemotor is going. I’m a little concerned about his feelings being hurt. Go easy on him.
Man, you sure do think about me a lot… You do realize this is a family friendly forum, yeah?
I really need to un-ignore you. I keep missing your comments. And, get my responses out of order. Don’t take that as me stepping on your toes again. It was an over sight.
I don’t forget anything. Especially a smart ass online. You’ve been that and more. The same exact way in the past. So, don’t get all bunched up when you get the same in return.
Now, stop commenting on online forums while on a date. Ole busted might get mad.
You aint the brightest neon under the ricer, are ya..
Easy rider imma be honest with you shut the fynk up with your negative homo ass or your going to get reported kids get on this site like little motor said so be respectful only time ill ask nice you have been on other messages tlkinv out your ass do you even beling on this site this site is for people to get help on they rc stuff not be offened my a douche bag like you
I’m gonna be honest with you, you need spelling lessons.
