Scalded-dog
I got voted the local rc mechanic.. so a friend of a friend brought me a 2wd arrma fury to look at.
Sometimes when you gun the throttle.. it loudly rapidly clicks and doesn't move much. If you ease on the throttle it takes off and runs with no clicking... here what I've found...
Gutted the entire back end of truck.. slipper looks near new and was adjusted 1/4 turn loosened from fully tight.
Rear diff has leaked out all the oil.. gears appear to be perfectly intact without nicks or wear. Diff still has a little oil stuck to gears etc.. so is not completely dry.
Gearbox gears= fine .. spur and pinion fine and adjusted correctly.
Dog bones and cups = no wear that i can see.
Questions. Is the clicking just maybe the slipper because its running a 2s lipo.. and the slipper needs set to almost completely tight?
I dont play with electrics alot... could anything to do with esc be the problem?
Would the diff somehow be skipping since no oil? But that would cause gear damage wouldnt it?
Any other things i should look at?
Thanks as usual guys.
