MM Engineering
I just got my O.S CV-RX running the other day. It has about a half gallon through it. Compression is still good. Has a Hardcore cooling head and this is on a XXX-nt Drake.
I went up to the mountains the other day and i figured i had to re-tune because of less oxygen. So I did... kinda. I richened up both needles and now I'm totally lost.
When i start it the mill runs fine. After i heat it up though, its a different story. After i go WOT then come back down to idle (like if I'm breaking), the engine will only run for about 1 second then die. Then if i try to start it up while hot it wont start till it cools down.
Also, can someone tell me that damn fuel line pinching technique... i used to know it but its DAMN tricky to learn for me... it just doesn't stick.
Thanks in Advance.
Thanks in Advance.
