What’s your idle like now?so i leaned high speed half turn and its very responsive now BUT after doing some short burst wide open throttle blips it jerks at idle. am i too lean now? is the perfect tune somewhere inbetween the half turn - i have yet to touch the lowspeed
the idle is perfect at startup but after high throttle blips it’s like a idle hang will try again todayWhat’s your idle like now?
Check your linkage too - it may be "hanging up" on you.
When you noticed the "idle hang", does the idle change when you hit the brake?
You can also test this with the engine off.
1. Turn the transmitter and receiver on.
2. Simulate full throttle.
3. Let off the throttle without hitting the brake.
4. Looking at the throttle linkage and/or down the carbs throat - hit the brake.
6. Do you see any movement?
5. If so, your linkage / return spring arrangement / possibly the carbs orientation / even possibly the "uniball" at the end of the carbs slide needs adjustment.
So when I brake it closes just a tad I think it’s the linkageCheck your linkage too - it may be "hanging up" on you.
So I’ve only done this with the new carbThe idle stop might need to be lowered a little from factory setting once you start leaning out the needles.
I think adjusting the collar so the spring is compressed more is the solution - at idle you need some tension keeping it shut, brake should be freewheeling.At this point I’m thinking 2 things
- compress spring more ( so at idle the spring will force boot closed vs slightly pressing brake )
- tighten the plastic cup that hooks into boot arm ??
Yes good solution will do this and updateI think adjusting the collar so the spring is compressed more is the solution - at idle you need some tension keeping it shut, brake should be freewheeling.
