Xmaxx motor amps
It will depend on so many factors, nobody could give you an exact answer. Weight of the vehicle, driving style, tires, gearing, traction, terrain, etc will all change the amps needed by the motor. It's exactly same as asking how much fuel does a monster truck use. Buy 50C or higher LiPo's from Liperior, CNHL, or SMC and be done with it.
If you need a good charger here is what I use.
It will depend on so many factors, nobody could give you an exact answer. Weight of the vehicle, driving style, tires, gearing, traction, terrain, etc will all change the amps needed by the motor. It's exactly same as asking how much fuel does a monster truck use. Buy 50C 5000mAh or higher LiPo's from Liperior, CNHL, or SMC and be done with it.
THIS! 👆 (fixed it for you :) )
