but isn't the travel the same in front and rear shocks???therefore making the droop te same?
Toolman said:The front wheels have both up & down movement as well as left & right movement which limits the maximum angle on the universal before it can bind. On the rear you only have movement in one axis so you can move through a greater angle with no binding.
Lessen said:Hmmm.. I don't think that's right.
If you have a joint and bend it at a given point along axis X by a measure of 30 degress you will have an angle of 30 deg along plane A. If you then turn one segment of that joint along another Axis (Y) by 30deg along plane B you still have an overall angle of 30 degrees on plane C. The angle does not compound. I don't think the angle of the universal when turning would limit the maximum angle creating with suspension movement. I think the limits are equal
Toolman said:the geometry is a little more complicated in that you have caster angles and steering akerman which steers one side more than the other.
Lessen said:what about 2WD stadium trucks and buggies? They also have stagger style shocks, but they don't have front drivetrain to contend with.
Lessen said:It may be that simple.. What I find is that every answer seems to pose another question.
Toolman said:I asked this question to Jamie Booth who is the distributor for Hong Nor (Jammin) in the UK and is a really really good driver!
His reply was as follows:-
Hi Tim,
I think you are on the trail, but I think the reason is much, much simpler.
Because the front wheels turn left and right it's often not possible to have the shocks mounted so far out on the wishbone as on the rear. If the shocks are moved in on the wishbone they need less movement for the same amount of travel, therefore having the same length of shocks on the front would A) make the car ugly and vulnerable to damage and B) it would be totally unnecessary.
