Well, if the metal one is worn out, it will make your diff/spur gear wear out faster too probably. But I would suggest running both gears anyway, and seeing which gives you better performance for the type of conditions you are driving in. If you like the 15 tooth, then buy a replacement that isn't worn out. If you like the 14 better, then use the one you have.
