where is reverse???
Whichway
RCTalk Rookie
Went and bought the dx3r pro...not the problem...installed the 3100 receiver with no problems also. Even successfully did the bind! Problem is that I have no reverse function. Is there something in the settings portion that I missed, because I have read the manual several times and can't seem to find what I need to do to make it work the way it did on the traxxas transmitter! Also, the motor spins constantly if I take my finger off the brake/reverse side of the trigger. Any one know the fix? Help please....
never mind....must have been the initial bind...have re- bind and have everything!!!
where is reverse???
On the old VW Beetles you had to push the stick down, then left, then forward.
On a 3 speed on the column, it's toward you then up.
On an automatic it's the first click out of park.
On 4 speed floor shifts, it's either left or right, then forward.
On an M35A2 Army 2 1/2 ton 6x6 reverse is all the way toward you and back. on an M1 Abrams it is one click to the right of Neutral.
No Problem, Rolex. I have the grid coordinates and FDC is set for a TOT there.
I've also got a box of grid squares, a package of reticules and a can of squelch.
Might as well bring the reel of flight line too!! You never know!!!:)
On a C-130 Hercules reverse is the throttles pulled all the way to the rear. ***Note*** Reverse only works on the ground.
Reverse doesn't work real well on an Abrams in flight either, Joey.
