Also remember, the torque from these bigger engines will get the car out of line due to the centrifical forces from the flywheel as well as the crank. The car will ahve to be setup to compensate for this. .12's are typically mid-high performers with snappy holeshots (provided the clutch engagement is setup correctly). Also, CG is affected from the bigger cooling heads so lateral stability is compromised.
In a nut shell, the .12's are the true racers. .15's are still roar legal, but in a different class. .18's are strictly outlaw. For both .12 and .15's, there is a 3 port limit. Over that and you're running outlaw.
Remember, bigger is not necessarily better. Case in point, my schumacher Fusion21 had a BB .21 engine in it with a 3 speed. It was rated to hit over 70+mph,and it did on a regular basis. When compared to my brothers NTC3 with an RB V12 3port (.12) side by side in a drag and on a laid out track, I was out handled as well as beat every single time in the holeshot. Given enough room and I would win, but in a real race situation, that was never the case.
