Buey36
Whats the difference between a N3 an a N4 glow pulg?
The only exception to the 260° is the Traxxas 3.3 which runs hotter (about 270° or so).
I always seem to get in trouble when I talk about glow plugs
Unless your running in Cold weather then Hot Plugs will work best the rest of the year Medium heat when temps are 75 degrees and above.
I always seem to get in trouble when I talk about glow plugs because I tell stories that are true and others do not believe them just because you can run the wrong plug does not mean you should. LOL.
The best all around glow plug for 10% to 30% nitro are Medium heat plugs. Unless your running in Cold weather then Hot Plugs will work best the rest of the year Medium heat when temps are 75 degrees and above.
What you pay for the plug is a choice you make. While you can buy inexpensive plugs in the long run middle range priced plugs will last longer. I have been using Fox Glow Plugs for a little over 9 years now and they are middle of the road priced. They were developed for Airplane engines orginally and then sell them for on road R/Cs. I can run a plug for about a gallon of fuel unless I run too lean one day then it will fry.
I have used many glow plug manufactures over the years. Duratrax Carbon Speed is a good inexpensive plug and medium heat will last all summer most of the time.
OS Glow plugs top of the line and one of the most expensive and will run for over a gallon of fuel. They are about the only manufacture that makes Turbo Plugs for my OS TZ engines.
You will never hurt an engine by running a rich mixture but there is a fine line between performance and maximum heat of the engine when running on the edge or too lean. Temp guage is suggested when you run an engine to maximum performance. Keep your engine temps below 260 Degrees but better to run on the rich side in the 220 to 240 range. Your engine will last longer
Josh stop the crazy talk... JoeMAXX is GURU! He has around 175 years of nitro experience. You are not going to tell him ANYTHING... no really.... he does not listen to anyone and will argue with a stump.Temp actually has very little to do with your tune. Sure a bad tune can make an engine run hot but a perfectly tuned engine can still hit 300+ in tall grass or high load situations. Also some engines just run hot ... my 5.9 in my XL has over 6 gallons on it and it very rarely runs below 300.
Follow robins tuning guide and quit worrying about temps and your life will be much easier.
lawlJosh stop the crazy talk... JoeMAXX is GURU! He has around 175 years of nitro experience. You are not going to tell him ANYTHING... no really.... he does not listen to anyone and will argue with a stump.
