Glow plug testing
You test the glow plug with the igniter, I would guess you test the igniter with a new glow plug.
Hi
For the igniter get a 1.5v flashlight lightbulb and stick it into the end of the glow igniter and if it glows brightly your good to go, and if it glows dimly charge the battery, I used to carry one in my nitro tool kit just for that purpose, As for the glow plug if the igniter has a good fully charged batter then the glow plug should glow brightly, and if it glows dimly it's at the end of it's life, it will still work but not very well.
Hi
Good tip ,just got this car it was a basket case was left out in the elements replaced the servos and remote control and receiver, got to the mechanical side flushed gas out and replaced with new put in new glow plug,and replaced the igniter,still no start, did a partial flush of the motor,and carb. Thanks for you help
So i should see a glow with it out of the motor correct, got nothing , was a new igniter and plug bought another and more glow plugs medium range (hot)
Hi
Do you have a picture of the igniter? Knowing what it looks like might give use an idea whats not working.
Hi
Hi
Here a picture hope it helps
Those bare-bones ones are barely functional, same goes for the included charger. I've purchased a bunch of RTR's that included them and about half were useless out of the box.
You'll have a much better time upgrading to one that unscrews and lets you change the battery, or even one that has an integrated battery and USB charger. Some have a little current meter in the back that verifies that the glow plug is working too.
Hi
The blue around the center looks like corrosion, if it if then the battery is toast.
Yes nothing ,ordered a new igniter and plugs hoping to be burninĝ nitro next. Weekthanks
It was just a shot in the dark my friend. I'm an idiot when it comes to nitro stuff.
normrdz300
Replies
8
J’sCrawler
J’sCrawler
S
Replies
3
SAVAGETITAN
S
