What is this guy?
Borkhart
RCTalk Racer
Active Military
Cambridge, IL
Hey everyone a guy I work with brought me his little brothers rc buggy and wants me to clean it up and get it running again. Does anyone one know what it is and whey engine this is! Thank you!
Sent from Borkharts HTC DNA
I think you right found the body it says ultra of pro. And I think they came with a .25. The fuel tank has old syrup look stuff in it. Nasty. And carb is gummy. What glow plugs do those engines take?
You seem to be missing the entire top of the motor. It will most likely need a rebuild if it has been sitting like that.
As for the tank, take it off, run some soapy water through it and get all that crap outa there then re install it. The nitro probably evaporated outa the fuel, and all you have left is the oil.
Lx one for sure,the tank has a built in filter that is gonna be clogged,and I bet that the lid seal is bad ,buy a new tank ,7$ on eBay trust me,I have many parts for this buggy if interested, you can pm me anytime bud
transmited from a mobile communications device
I have the cooling head I took it off to see what the inside of the engine looked like. Top of piston is a bot dark but moves ok and needs a new plug. What is the stock replacement plug. And I will probly toss you a pm when I dig into this bad boy and see what else I need lol.
This piece the shaft is bent something fierce. Where would I got about getting a replacement one
Huh! What piece,did you forget the pic
Lmao,...eBay is gonna be the place,there not so cheap either,I know for sure there are a bunch on ebay I just added a set to my watch list,those are about the only parts I don't have bud
haha oh great how much are they usually, and what is that part on these called exactly?
EDIT: Found the part, what glow plugs go into the .25?
I dig the finger point! Reminds me of ET,lmao....remember? ......your axle stub is what your pointing at,you may have to search "cvd" to find it,I'm not sure if the lx2 ones will fit but my gut tells me that the lx2 uses an 8mm as apose to a 6mm,I hope someone can weigh in on this
the manual for the pro says its a 6mm shaft. but gives me no reccomendation of glow plugs weird.....
I think I'm running an OS med in mine,not a long reach
I just picked one of those up used on ebay too. The chassis is really prone to flexing and bending the rear tower.
As for the axle, they are stubs, I'd take the one out you have and hammer it as straight as you can on something flat. Is a weird design, the knuckle/dogbone/stub are 3 different pieces.
Mine was in pretty sad shape when I got it. Engine was shot, diffs were dry, everything was covered in oil/grease... was a real mess.
I cleaned it all up, put lube/oil where it belongs, ditched the engine in favor of an LRP28, made a couple braces for the rear tower and now it sits and waits for warmer weather.
If I was keeping this I would definitely buy another engine and spruce it up a lot more but I'm just getting it run worthy for my co-workers little brother. They. Never did any maintenance to it at all its covered in rust and old oil and dirt. Head shims were trash. Have to get some of those to. Things a mess for sure but I like projects and they are paying for it.:)
