hah, flash you think your v-spec was bad. mine needed the MSN leaned out a full turn.
for proper MSN tuning:
you need to turn the LSN an EQUAL AND OPPOSITE amount to whatever you adjust on the MSN. if you fail to do this, you will screw up your LSN setting in the process.
example:
if you lean the MSN by 1/4 turn, you need to richen the LSN by 1/4 turn.
only tune your MSN after both your HSN and LSN are properly set. failure to do so WILL totally mess up all your settings. to check for MSN tune, you need to drive at part throttle for about 5-6 second then punch the gas. if it bogs, lean the MSN by 1/8th of a turn. repeat until its snappy from mid throttle. if it lean bogs the first time you try it (stutters, sounds raspy, very little smoke, then takes off) then richen the MSN by 1/4 turn until its snappy.
