"generic stadium truck' (ultimate rustler)
i wanted a proper rear motor stick pack using stadium truck i could use without worrying about parts support and unfortunately this is the only thing left. its old, outdated, and frankly isn't that great. but its functional and has aftermarket support out the yin-yang so i bit the bullet and built this from scratch with as many aftermarket parts as possible. in fact i think it only has 6 OEM part numbers on it. and if i had to do it over i could eliminate at least 2 of them without changing the budget. and if i wanted to spend the money (an extra $100) i could eliminate another.
here's the parts list with part #'s (OEM omitted):
RPM Front Shock Tower - 80852
RPM Rear Shock Tower - 80832
RPM 30 Deg Caster Block - Blue - 80715
RPM Gear Cover - Red - 80529
RPM Rear Stub Axle Carrier - Blue - 80385
RPM Front Bearing Carrier - Blue - 80375
RPM Rear A-Arms - Blue - 80185
RPM Front Bulkhead - Red - 73759
RPM WIde Front A-Arms - Blue - 70665
RPM Wide A-Arm Screw Kit - 70680
RPM Adjustable Front Body Mount - 81122
RPM Wide Front Bumper - Red - 81169
RPM Motor Protector - Blue - 80915
RPM Bumper Mount - Blue - 80905
RPM Short Turnbuckle Rod End Set - Blue - 80475
RPM Long Turnbuckle Rod End - White - 80511
RPM Hybrid Gearbox Housing & Rear Mount Kit - Blue - 73615
Hot Racing Aluminum Steering Crank w/Serov Saver - HRATE48X01
Hot Racing Hardened Chrome Plated Steel Hinge Pin Set - HRASTE1568E08
Hot Racing Aluminum Pivot Ball Set - Red - HRASCP160B02
Hot Racing Hardened Chrome Plated Caster Block Pin Set - HRASTE04HP
Hot Racing 90mm Aluminum HD Big Bore Shock Set - Blue - HRATD90X06
Hor Racing 100mm Aluminum HD Big Bore Shock Set - Blue - HRATD100X06
Hot Racing Super Duty Sliper System Small - TRX15G06
Hot Racing Aluminum Idler Gear 30 Tooth - TE1000
ST Racing Concepts - 12mm Aluminum "Lock Pin Style" Wheel Hex - Red - SPTST3654
ST Racing Concepts - ALuminum Front Hinge Pin Brace - Red - SPTST2532
Drag Race Concepts Kingpin Steel Idler Gear Shaft
Drag Race Concepts 22T Top Shaft Gear T6 Hard Coated - 10055
JConcepts 12mm Hex 2.2 Super Dish Wheels - White
JConcepts 1993 Ford F-150 Body - 0375
Proline - Trencher T 2.2 Tires - 10121-00
Team Associated M4 ALuminum Flanged Locknut - Blue - 31551
MIP C-CVD Kit - 08123
175RC Aluminum Wheel Nuts - Red - 175-18640
Fast Eddy Sealed Bearing Kit - TFE1168
RC Screwz Stainless Steel Screw Kit - RCZTRA020
Homemade Parts:
ESC mount/tray. its 1/8 fiberglass.
battery strap. also 1/8 fiberglass and designed and cut out on the CNC at work. utilizes Team Associated screws and body clips.
and the electrics:
Futaba 3PV radio
Castle Copperhead ESC
Tekin Gen 4 Spec-R 10.5 motor
Reedy 2513MG servo
2s lipo's.
Truck
Other
1/10 Scale
Electric
LiPo
Brushless
Drive System
2WD (Two-Wheel Drive)
Top Speed
40-59 mph
figuring out how to build an entire rustler out of as many aftermarket parts as possible and still having to give traxxas a few dollars of my money.
Suburban_Hooligan
More from Suburban_Hooligan
