jcrane81
how do u decide how much weight u need in your rims on your crawler
I may try removing the weight from my rear wheels and see how it performs, or at least reducing the weight. It's not like I compete with it, or ever really will, but I do enjoy crawling down by the light house, so if it helps any I will be happy. Both weighted was definitely better than no weight though.
So re-type it, I'd like to read it![]()
What do you mean by an under drive gear set?
Curtis, I am running a 55 turn motor, so I guess these gear sets wouldn't be a good idea unless I changed out my motor too? What motor are you running?
Joe I run a 35t motor on a 3s lipo so that I have lots of wheel speed and still have great low speed control as well, if you plan on sticking with the 55t motor you could do the overdrive gears in the front axle and the heavy duty stock gear ratio in the rear, personally I'd go with a 35t Integy motor and the under-drive gears in the rear because I don't want to give up the gearing in the front axle and take a chance of not having enough torque.
