Build Thread Warby's TRX Nitro Sport, spare parts build
Been cleaning more parts and assembled the front assembly. I've fitted a RPM front bumper since I will be bashing this one.
I've fitted nylock nuts where possible to prevent screws pulling out of plastic.
Gearbox was in good order.
All I did was clean it, new bearings and shims and add new grease. The old bearings were OK but I replaced them anyway for peace of mind.
I also opened up the diff and greased.
Gearbox in. I'm just using the standard output yokes atm but I'm going to order some steel ones. When I do, I'll fit all new drive shafts.
The steel shafts of the diff didn't have a hole for a through pin so I had to use the grub screws and the centre screw. Must be because it's an early version I'm guessing.
This one is coming together pretty quickly!!! 😎
It is indeed. I'm being less particular and I have most parts required. But as of Wednesday, it won't be touched for another week as I go back to work.
Well, I got a lot more done than I was expecting, over the last few days. But that's it for another week.
Where's were it's at:
Whats left:
  • Clean, refresh and fit the engine
  • Order missing parts
  • Fit steering turnbuckles and servo
  • Fit throttle/brake linkages and servo
  • Glue wheels
  • RX and TX
  • Wheel alignment
  • Body
I'm also going to order new clutch shoes as the old ones are oil soaked. The metal drive yokes and a new servo saver. Mainly because I don't want to have issues with them later.
I foresee a RPM front shock tower being required one day but I'll cross that bridge when I come to it.
