Reddog
RCTalk Champion
I was once again asked to help out with getting a used nitro truck going that someone had bought on a sale.
Here are the basic things I tell people and just what I do.
First off clean everything, and by this I mean tear it down and wash it like it was new. Simple green works well for this. Once clean inspect everything. Look for cracked or broken plastic, missing or damaged teeth on gears, twisted driveshafts. Test the electronics. Turn on the radio and get someone to watch it as you walk away, see what the range is. Once everything has been cleaned inspected and worn, damaged or missing parts repaired or replaced reassemble. Now on to the engine. Clean it. Inspect it. Now tear it down and clean and inspect every part of it. If all is in good order reassemble it and seal it up good. Install the engine with NEW fuel lines. Once all of that is done and the truck is all back together put in a new glow plug and fresh fuel go ahead and try to start it up.
From here you move on to tuning and minor adjustments.
So do you all thin I am directing folks right? Shaun
